Old 09-14-2017, 10:03 PM   #1
Buda63
Buda63's Avatar
Weekend Project - Fuel Tank and Steering Column
I received a rebuilt steering column from Kev's Classics and a an OEM fuel tank from Classic Industries. I will be replacing both this weekend and wanted to know if anyone has any advice, do's or don'ts for these projects. Thanks for the help.
Buda63 is offline   Reply With Quote
Old 09-15-2017, 05:02 PM   #2
Clrussell
Clrussell's Avatar
Re: Weekend Project - Fuel Tank and Steering Column
Don't smoke. And do use wd40
61 apache
Clrussell is offline   Reply With Quote
Old 09-15-2017, 06:43 PM   #3
shp4man
shp4man's Avatar
The fuel filler rubber hose is not easy. Be patient, get a new hose, and review your cuss word inventory- you'll need it.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 09-15-2017, 08:19 PM   #4
rvrfoot
I cut my finger trying to replace the fuel hose.
rvrfoot is offline   Reply With Quote
Old 09-15-2017, 09:15 PM   #5
DPowers
One foot in front of the other
DPowers's Avatar
The gas tank install is much easier with the seat out.
Us old guys forget how stuff goes back together so take pictures of how the original column is installed before taking it apart.
Replace rag joint.
DPowers is offline   Reply With Quote
Old 09-15-2017, 10:51 PM   #6
vetnat
When unbolting the rag joint from the steering box - completely remove the bolt, don't just loosen it. Sometimes the bolt itself without any tension on it is enough to keep the rag joint stuck on the splines.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 09-16-2017, 12:03 AM   #7
rvrfoot
Show some pictures if you can so others can see if thay have any questions.
