09-15-2017, 09:47 AM | #1 |
LS conversion motor mounts?
Looking for some advice on LS swap motor mounts for my 68 step side? Took out the straight 6 and there are so many companies out there making them. Seeing if anyone had good experience with one company from another.
09-15-2017, 10:11 AM | #2 |
Re: LS conversion motor mounts?
I bought the newest CPP sheet metal engine and frame mounts from summit racing. They fit perfect. My truck is a 70 c10
09-15-2017, 11:16 AM | #3 |
I've got the CPP mounts also.. perfect fit.
https://www.ebay.com/itm/29620574751...mis&media=COPY |
09-15-2017, 12:13 PM | #4 |
Dirty Dingo Sliders look really promising. The nice part about them is that depending on your previous setup, you can just slide the mounts forward and back to hopefully maintain your previous driveshaft. With a lot of the conversion mounts out there, there are only a couple pre drilled mounting locations. With the sliders, you can fit it exactly where you want to.
09-15-2017, 12:36 PM | #5 |
CPP were the ones I was leaning towards but just wanted to see if anyone had experience with them. Thanks
09-15-2017, 12:58 PM | #6 |
Do the CPP mounts put the LS engine in the same position as the stock V8 ?
09-15-2017, 02:05 PM | #7 |
CPP mounts are adjustable. The frame mounts do go in the stock location. CPP engine mounts are adjustable within reason very similar to the dirty dingo sliders. I chose the cpp mounts because I did not want to drill holes in my cross member. The sheet metal frame mounts bolt in stock location.
09-15-2017, 02:07 PM | #8 |
This might get moved to the LS swap section.
09-15-2017, 03:15 PM | #9 |
I used these from POL. https://www.performanceonline.com/19...-Brackets-V-8/
They work in either the V8 or 6-cylinder position, clearance for any kind of headers or manifolds, look clean and simple. Don't use the cheap Chinese rubber mounts, though. Go ahead and get the Energy Suspension urethane mount upgrade.
09-16-2017, 01:24 AM | #10 | |
Did you get the LS Conversion Brackets too? Looks like everything is $284? |
09-15-2017, 04:04 PM | #11 |
I recently dropped my engine in on Early Classic mounts. Its not done yet but I like the way it sits. Fits well with a ctsv pan that is easily available, has room for a low mount a/c compressor with minimal frame tweaking, and allowed a 4l80e to go under a low hump tunnel.
09-15-2017, 08:00 PM | #12 |
I used the Speed Engineering adapter plates...they worked well.
09-16-2017, 01:29 AM | #13 | |
https://www.speed-engineering.com/ls...3-ls6-ls9.html I don't see any for our year trucks. |
09-16-2017, 07:35 AM | #14 | |
02-06-2019, 04:20 PM | #15 | |
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
02-06-2019, 04:36 PM | #16 | |
02-06-2019, 09:06 PM | #17 |
MDPotter, the Speed Engineering adapter plates will work for your mounts without issue.
02-07-2019, 12:09 PM | #18 |
If you want to use the factory perches and have the bolt through the back of the motor mount use these. https://www.summitracing.com/parts/ens-3-1156g
I used factory perches with those motor mounts on dirty dingo sliders. It can be a pain by yourself to get the bolt lined up going from the perch to the motor mount since you can't really see it. Do some aftermarket perches that have the bolt through style change the motor height/position compared to the factory perches? I see some people run the AC compressor down low and some move it up because of clearance. |
02-07-2019, 03:26 PM | #19 |
I used the dirty dingo sliders on my 68 and I didn’t like them for a couple reasons. They sit up 1/4 higher than stock so I had to bend the tab back in the transmission tunnel with my 4l60, and also if you want to slide the motor all the way forward you have to trim the passenger side rubber mount. But other than that they worked and looked nice.
