Old 09-16-2017, 12:54 PM   #1
hop sing
hop sing's Avatar
Frame I.D
Can anyone help me with this frame number that I found on my truck thanks hop
Save a tree support your local drag strip !!!
hop sing is offline   Reply With Quote
Old 09-16-2017, 09:51 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Frame I.D
What year truck?
Top of the frame drivers side?
O =Oakland
1 all serial numbers started with a 1.
13,146th truck built on the assembly line.
Old 09-16-2017, 10:52 PM   #3
hop sing
hop sing's Avatar
Re: Frame I.D
What year truck?
O =Oakland
got a bastard truck its suppose to be a 1962 cab no numbers on cab and its definitely not a T bar frt end have a feeling it a 63 thru and thru going to check cab mounts in morning,,, I remembered ,,, thx to capt fab that body mounts were different 60-62 check I will see if they drilled a whole in floor board for cab mount hopefully that will tell the story there ,,mahalo for da help Hop
Old 09-17-2017, 07:21 AM   #4
aerotruk63
aerotruk63's Avatar
Re: Frame I.D
Does the cab have two holes for the dual master cylinder for the brake and hydraulic clutch or a single for the master? Quick way to determine a 63 cab.
Old 09-17-2017, 11:30 AM   #5
oldarky66
Re: Frame I.D
LMCtrucks has an ID/history chart at the beginning of their catalog. You can view it online. It shows 1960-64 chevy first digit equals year, second is a letter either C for 2wd or K for 4wd, next 2 digits 14=1/2ton swb, 15=1/2 ton lwb, 25 =3/4 ton lwb then 4 for truck etc..
1965-66 chevy first digit is C or K for 2wd or 4wd, then 14,15,or 25 for 1/2 ton swb, 1/2 ton lwb, or 3/4 ton lwb, next is 4 for truck, then 5 or 6 for year, etc.
1960-66 GMC begins blank = 2wd, I = inline 6 cylinder engine, or k for 4wd, next 10 for 1/2 ton, or 15 for 3/4 ton. Then 01 for swb or 02 for lwb. etc.
Yours doesn't seem to fit any of these. Hopefully someone can give you more info. Good luck.
oldarky66 is offline   Reply With Quote
Old 09-17-2017, 11:51 PM   #6
hop sing
hop sing's Avatar
Re: Frame I.D
thx ,really got taken on this truck lucky I got spare titles and numbers from other trucks I have stripped the last ten years over five of them from 60-64
Old 09-18-2017, 12:39 AM   #7
shortstep60
Re: Frame I.D
If it has the x frame its a 1962
shortstep60 is offline   Reply With Quote
