09-19-2017, 09:16 PM | #1 |
'60-66 American Auto Wire questions
I just bought a brand new wiring harness for me '62 and was wondering about the headlight wires, in the top corner by the master cylinder there was a plug/grommet and on the replacement it seems like the new wires just run right through no plug, are people just running it like that or putting a plug in?
http://67-72chevytrucks.com/vboard/s...d.php?t=698214 my '62 build |
09-19-2017, 09:19 PM | #2 |
Re: '60-66 American Auto Wire questions
I have done both actually. If a show vehicle then get a plug.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-19-2017, 09:27 PM | #3 |
Like 64 Patina I have been wondering about the same thing. Will run a new harness soon and would rather use something that looks professional as opposed to typical hardware store rubber grommets. Any sources for what the pros use to bundle wires and pass through the firewall (with some weather protection) would be very helpful.
09-19-2017, 10:20 PM | #4 |
Put a plug in it.
09-19-2017, 10:35 PM | #5 |
Moderator
I think the one your referring to is this one: https://www.americanautowire.com/sho...tor-kit-9-wire
09-20-2017, 08:13 PM | #6 | |
09-20-2017, 06:48 AM | #7 |
All that was in my AAW kit I used on the 65. Some assembly required. What kit did you get? I used the classic update kit for these trucks.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-20-2017, 07:23 AM | #8 |
Mine had the plug as well.
You can see in this pic I don't have the headlight harness plugged in. 20170914_144344 by bjohnson388, on Flickr Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
09-20-2017, 11:39 AM | #9 |
mine has the plug but did not come with the rubber gromet
09-20-2017, 12:36 PM | #10 |
When you buy the wire harness the rubber is not in the kit.
09-20-2017, 03:14 PM | #11 |
I was able to use the original grommet. It wrapped perfectly around the new harness.
09-26-2017, 07:18 PM | #12 | |
09-20-2017, 08:11 PM | #13 |
I got the same one man
09-20-2017, 08:10 PM | #14 |
Thanks for all the feedback! my kit didn't come with the plug but I'm going to look into getting one
09-21-2017, 11:53 PM | #15 |
Quick tip: When you do the instrument cluster wiring, re-use the metal light sockets. Use the new connectors in the AAW kit, but use them with the original metal sockets that snap into the back of the instrument cluster.
That's the only complaint I had with my kit--the plastic light sockets left a lot to be desired. The rest of the kit was top-notch! -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
09-22-2017, 09:21 AM | #16 |
One thing i havent had time to figure out yet is the wiper wiring on mine. I have a 62 and the plug is right but the second i put the fuse in it it pops the fuse.
Anyone know anything about what changes need to be made for this? they are just the single speed 62 wipers. And i am using the AAW kit.
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
09-22-2017, 07:52 PM | #17 |
DeD short inside the switch would cause that to pop.
A dead short wife would also do if. I had the same problem with a factory spot light.
10-01-2017, 09:44 PM | #18 |
Brad, i guess thats possible, but it worked before i changed the harness thats whats confusing me, and im usng the single speed wiper, is that an issue?
