09-20-2017, 05:42 PM | #1 |
Help me decode my motor!
Looking for someone to help me figure out what motor is in my truck. The casting on the block on the drivers side towards the firewall is: 3956632. I read that this makes it a 307 from 1969. Is this right? Also, on the front pad on the passengers side there is stamped the code: VO428U5 (The last number is definately a 5 and not an S. I will post pics soon) I have not been able to find this code anywhere. If anyone can shed some light on what I have here that would be great!
'68 Chevy K20 '72 Chevy K20 - Smokin' Ochre '08 Mercury Grand Marquis - Daily driver/ Parts fetcher Ohh uh, I didn't have time to fix everything... |
09-20-2017, 05:59 PM | #2 |
Re: Help me decode my motor!
http://www.nastyz28.com/sbchevy/sblock.html
The z28 forums say you're correct. You are in fact a 1969 307, as far as decoding the other numbers I have no clue, I'm still learning how to myself |
09-20-2017, 08:59 PM | #3 |
Moderator
VO428U5
V Flint Michigan Engine Plant 04 April 28 28th U5 I believe is a mis-stamp should be US Which translates to US: 1979 305 LG4 H 160 4 Cutlass The U5 mis-stamping issue has been around for a long time... I believe it's possibly due to the use of "gang stamps" for engine number allocation. Your engine is a transplant from all indications. |
09-21-2017, 04:20 PM | #4 |
You have a 1969 307. Your casting number 3956632 is for a 1969 to 1973 passenger car Chevelle Camaro Nova or Truck. I'm sure that you have a 5 stamped in your block, but when the 5 was stamped it was intended to represent a S. They did that all the time at the engine, transmission and rear end assembly plants. I's used as 1's are very common. lots of cases documented where letters were used as numbers or numbers used as letters. Sometimes a worker would misread a stamp and put it back in the wrong spot or a commonly used stamp would wear out and a similar looking letter or number stamp would be subsisted.
Your application code of U5 is meant to be US. In 1969 US decodes to a 1969, 307cid, 200hp, manual trans, 2bbl carb, Truck motor. If you want you can check your date code(opposite flange from your casting number) just to be sure. EDIT: U5 followed by a letter was used from 1986 to 1990 for 350 truck motors. But your casting number eliminates that as a option.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 09-21-2017 at 04:32 PM. |
09-21-2017, 04:30 PM | #5 | |
10-01-2017, 09:41 PM | #6 |
I am always amazed at the wealth of knowledge from the people on this site. Thank you so much for the great information! It all makes sense now and I really appreciate all your input guys. I love that there is always something to learn about these old trucks!
10-30-2017, 04:11 PM | #7 | |
10-30-2017, 05:56 PM | #8 | |
3914678 = 302, 327, 350 in 1968 C 15 8 = March 15th 1968 Casting date V0319YV = Flint, March 19th, Assembly date, YV = Truck motor, 327ci, 240hp, Th400 trans, 4bbl, Your truck is a 1968 right? The motor in post 1 is a 69. Is that original to your truck? If so we need to check the casting date. The books aren't always right. Also engine casting dates are always the actual year and month cast. Model years on trucks/cars are split. Some 68 model trucks were built in Sept, Oct, Nov, or Dec, of 67. If your truck is a 1968 then you won't get much closer to correct than the motor you located. Your located 1968 327 motor was cast march 15th of 1968. Your truck could have been built before that. How close are you trying to get?
CHEVY/GMC VIN DECODERS |
11-06-2017, 10:51 PM | #9 |
Not trying to hijack this thread but I'm new to these forums and don't know how to post my own yet. But...I'm learning. Can someone help me? I found lots of info on SBC and BBC but very little on V6.
Talk about frustrating! Anyone called GM recently? After an hour and a half on the phone with 6 departments I'm no further in my quest than I was earlier. Hopefully someone on this board can help. I am in the process of building a hot rod 28 roadster. I've decided to use a GM V6 powerplant for a number of reasons. Anyway, I was able to pick up a V6 pretty cheaply. Before putting in the roadster I want to rebuild it. In order to rebuild it I have to identify it so I get the correct parts. Seems simple so far, right? Well, everyone wants the year, make, model and VIN of the donor vehicle. I tried to explain to GM that is what I am calling them for. If I had that, I wouldn't need to be calling. Anyway, the VIN would only be valid IF the engine was the original for that vehicle. So, I'm looking for info from some of you more knowledgeable folks. Here's what I have and am trying to identify: GM V6 4.3 L 4bbl carb Engine ID = T1121UTC Block Cast = 10105867 I know T = Tonawanda Buffalo, NY 1121 = 11/21 It appears to be an 87-91 based on the casting number. Can anyone help identifying this engine further? Thanks in advance. Last edited by JimmyS10; 11-10-2017 at 02:03 AM. Reason: Got it. Thanks to everyone who looked. Jimmy |
12-04-2017, 12:26 AM | #10 |
Thanks again Bruceman for all the info. I have recently found another motor for sale locally with a casting number of 3914678. The seller says it is a 1968 327. The motor has been rebuilt by a machine shop, however it still requires heads and an intake to make it complete. I asked about the date code and the seller indicated that it came out of a 1968 Caprice estate wagon however the motor has been "decked" so the original stamping is no longer there. However it is the correct year and size of motor I have been looking for, and he is selling it for what I believe to be a fair price for a freshly rebult motor so this is the route I am now going to take. I appreciate all the information... now I have to start a new thread to begin researching what heads I want to run on this motor!
