Old 09-23-2017, 09:16 PM   #1
Bobby Pootz
Bobby Pootz's Avatar
Blue LED under dash and behind seats accent lighting
I've always been fascinated with interior accent lighting, heck I'm also into exterior accent lighting but this post is just the beginning of the lighting.
Fairly simple install, parts were cheap and time was a few hours.
I added a total of 4 blue LED lights, two under the dash and two behind the seat.
LED's were from Super Bright LEDs
https://www.superbrightleds.com/more...les/miniature-
rectangle-led-accent-light-black/25/
Add-A-Fuse from Amazon
https://www.amazon.com/Radar-Mount-D...rds=add+a+fuse
The rest was just simple wiring connectors and 18 gauge wire for power and ground.
I added the Add-A-Fuse to the fuse panel and jumped the Dashlights circuit so it comes on with my headlight. I soldered the wiring to make clean connections. The ground in the dash was just added to a screw as the body is the ground. And in the rear, I just drilled a hole in the top crease to make a ground.
The pics aren't the best but you can tell how it will look. As you might know, photographing lighting never comes out clearly but you can see how they look.
I've included 3 pics.
First - From inside the cab looking under the dash.
Second - From inside the bed looking inside the truck.
Third -Form the front of the truck looking inside.
For about $32 and a few hours of time, I think it's pretty bad ass!
Bobby Pootz is offline   Reply With Quote
Old 09-23-2017, 11:56 PM   #2
Bloodhound
Re: Blue LED under dash and behind seats accent lighting
I like it!
Bloodhound is offline   Reply With Quote
Old 09-24-2017, 12:39 AM   #3
ivorton74
ivorton74's Avatar
I had those in my old 74...one of the coolest things i ever did to it. Also put blue leds in the cluster and my sunpro tach. Plan to do it to my 83
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 09-24-2017, 08:43 AM   #4
TKCR
TKCR's Avatar
I like it!!!
I added LED lighting in my truck, just under the dash and then my door plates. I used white under the dash. I guess I never thought about using a color. I got a under the dash kit from LMC and added those 2 to the 2 that were already there, so 4 all together. And then I also upgraded the dome light and put a LED bulb in it too.
Old 09-24-2017, 05:08 PM   #5
Desert_Eagle02
This is a great idea. Thinking I'm going to do it in mine and wire it to the door switches since my dome light doesn't work. I think this would be better than fixing the dome light.
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 09-24-2017, 09:44 PM   #6
1957 Chief
Looks sexy fellas. I dig those sill plates....
Bubba
1957 Chief is offline   Reply With Quote
Old 09-24-2017, 11:00 PM   #7
Bobby Pootz
Bubba
Those sill plates are awesome too! I might tie a pair into my dome light. I can't get my under dash stock courtesy lights to come on and it's not the bulb.
Old 09-24-2017, 11:26 PM   #8
TKCR
TKCR's Avatar
Most issues with the dome light and/or courtesy lights are the door switches. The terminals usually rust and fall off the back of the door switches. I had this on my truck, my dome light & courtesy lights did not work. After doing some tracing, I found my wires were no longer attached to the back of the switches. They were laying in in the bottom, between the panels. So I got some new ones and reattached the terminals and "Then There Was Light"!!!
Old 09-24-2017, 11:39 PM   #9
Bobby Pootz
Thanks! I've already changed both door switches, the dome light comes with the doors opening but nothing under the dash. Thanks for the help!
Old 09-24-2017, 11:42 PM   #10
TKCR
TKCR's Avatar
Were there 2 wires on the left side/drivers side? Should be 2 wires on the left and 1 on the right side.
