09-24-2017, 02:36 AM | #1 |
How do you clean inside a side marker lens?
I removed the old gaskets from my side marker lenses but there is dirt/road grime inside the lenses up in the edges. I tried soaking in detergent water but no luck.
I have been told by a knowledgeable source these are glued together. How would you guys get that grime out? it looks bad from the outside of the truck. |
09-24-2017, 09:54 AM | #2 |
Re: How do you clean inside a side marker lens?
Unless you want original, or even NOS replacements, order a new set from one of the vendors here. For $50 or less you'll have nice clean lenses to accent your nice paint.
For years I struggled with the same conundrum until one day at a truck show I saw new ones on a display. Done. |
09-24-2017, 11:40 AM | #3 |
could you use a bottle brush. If you have a lab supply company around you , or even the internet, you might be able to find one. I have use tapered bottle brushes for cleaning test tubes in a lab, just a thought.
09-24-2017, 01:09 PM | #4 |
Bottle brush might be an idea to try. A junkyard guy priced his at $8.00 a piece, I'll call him and ask if those are new or old. Thanks guys.
09-24-2017, 01:46 PM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I used Q-tips and zip ties with pieces of rags glued to the ends. And for the best bang for the buck is "Purple Power" from Dollar General, that stuff cuts anything! Careful around paint with that stuff though because it is a mild acid solution cleaner but great for plastics...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
09-24-2017, 02:23 PM | #6 |
Old member
Small screw driver with rag on the end with some kind of cleaner soaked. Tooth brush may work also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-24-2017, 05:18 PM | #7 |
Get some long pipe cleaners from the craft section, fold them in half and twist a few together, works like a charm.
09-24-2017, 05:21 PM | #8 |
09-24-2017, 05:33 PM | #9 |
pipe cleaners- sounds like a good idea
