![]() Join Date: Sep 2017
Hi Folks;
This forum has been a big help while building my 1980 C10, this build is what caused this business to be created as I was trying to find fuel line to install my FiTech fuel injection and found it to be a big PITA. I thought I can do better so I got in touch with a ton of manufacturers and got samples. Did a ton of testing and found the best one to go to market. You can check out my Build Thread here. As a thank you to this Forum as one of the groups who helped me so much through my project I have created a promo code just for you guys. CHEVYTRUCK10 We have on promo right now 20FT of PTFE stainless or Nylon braided line. As well as 8 fittings of your choice - Choose from - Straight, 45, 90, and 180 degree fittings. Default fitting choice is 2 of each fitting. 2 - straight, 2 45, 2 90, and 2 180 degree AN6 fittings Perfect for Fitech or Sniper installs. LS swaps, Carbed applications. Very good chemical resistance compared to rubber lined hose. 114.97 for the AN6 AN8 also available $139.97 Free Shipping on ALL ORDERS www.hotrodfuelhose.com ![]() ![]() ![]() ![]() ![]() ![]() Thanks Justin Last edited by HotRodfuelhose; 10-05-2017 at 12:37 AM. |
Re: PTFE AN6 Fuel hose bundle deal
Are you going to get black fittings?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
Black fittings in AN6 are now in stock.
Black hose will be restocked next week. Black fittings with stainless hose is currently available. |
Hi my friend. The black bundles are now available.
https://hotrodfuelhose.com/collectio...-fittings-save |
![]() Join Date: Jan 2013
Justin,
Do you have kits for the Holley Sniper EFI with return to tank? I am using a 69 Camaro gas tank also by Holley with fuel pump and sender. I am installing the system in a 69 C/10 SWB. If so please Quote. Thanks, Wally |
Hey Wally the AN6 bundle for 109.99 should work well for that setup. I run the same on my 1980 with 383 and fitech. The only extra piece you may need is hardline to an6 off the sending unit. I have attached a picture of what that looks like on mine.
Justin,
Do you have that hardline too? |
Justine,
Thanks I will get it ordered this weekend. Thanks for your time. Wally |
Justin,
Would you happen to know the part numbers by chance? |
Thanks, I will be ordering the EFI system this weekend also. Appreciate you help.
#15 |
Kit on order Thanks.
#16 |
#17 |
Thanks hope it wasn't too bad. It will be awhile before I get installed. I will be breaking in engine with carburetor, after that I will send you some pictutes.
Wally |
#18 |
#19 |
AN6 straight fittings are currently SOLD OUT. We will be getting more but without the straight fittings the bundle is unavailable as well.
If you would like a Bundle with 45/90/180 degree fittings we can still make that work but you must message directly as the website will not process the order. AN8 is still available Thanks. |
#20 |
When will more straights be available?
#21 |
Shortly. I actually have 2 left as another customer chose to go with 45s instead. I can make one bundle work.
Let me know. |
#22 |
Pm sent
#23 |
Tags |
braided, fuel hose, nylon hose, ptfe, stainless hose |
