Old 10-01-2017, 06:25 PM   #1
JADF
1960 C10 LS Swap Questions
I'm looking to pick up a 1960 roller and throwing an ls into it. From my research, it looks like there's no kits for the 60-62 cars due to the torsion bars and x frame??
Would a front end swap make it so the 64+ ls swap kits would work? Or is there an easy way to get an ls into a 1960?
If anyone has any info on this please let me know!
Thanks!
JADF is offline   Reply With Quote
Old 10-01-2017, 06:35 PM   #2
rvrfoot
Re: 1960 C10 LS Swap Questions
Try looking in the search.
rvrfoot is offline   Reply With Quote
Old 10-01-2017, 06:37 PM   #3
JADF
Ive been looking in the search on here and all over google with no luck. I am pretty new to the subject so I may be at fault, but I can't figure out if a front end swap makes the ls swap kits work.
Old 10-01-2017, 06:46 PM   #4
Clyde65
Clyde65's Avatar
I would want disc brakes before I added power!
There are some... probably more 62's for some reason but they should be sane.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-01-2017, 06:47 PM   #5
Clyde65
Clyde65's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=694256
http://67-72chevytrucks.com/vboard/s...d.php?t=661818
Clyde65
Rebuild of Clyde
support our troops!
Old 10-01-2017, 07:04 PM   #6
ls60apache
hello look up 1960ape in the builds section he did a ls with 4l80e and kept torsion bars. I my self updated to a 73-87 front suspension... good luck with your project.
ls60apache is offline   Reply With Quote
Old 10-01-2017, 09:40 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
There are a couple build threads I came across recently, but I don't remember who they were. The two I read said they didn't have a problem with keeping the torsion bars. I think someone said something about using Camaro exhaust manifolds.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-02-2017, 09:09 AM   #8
Clyde65
Clyde65's Avatar
The Camaro or TBSS manifolds fit tighter than any other .
Clyde65
Rebuild of Clyde
support our troops!
Old 10-02-2017, 10:42 AM   #9
oldusafmsgt
oldusafmsgt's Avatar
The 63-66 kits will work, just need a spacer , 1/2 inch, on top of the frame rail. No problem with the torsion bars.
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 10-02-2017, 11:06 AM   #10
JADF
Interesting information here. I ended up picking up the truck last night and the more I think about it, the more I want to keep the torsion bars. So would this swap kit get the motor into there?
http://www.ebay.com/itm/63-67-Chevy-...tY5S32&vxp=mtr
and will these headers clear? they're the cheapest I've found.
http://www.ebay.com/itm/Chevy-LS1-LS...xUd9qP&vxp=mtr
Old 10-02-2017, 11:14 AM   #11
rvrfoot
The kit says 63 67. You have a 60?
Old 10-02-2017, 11:15 AM   #12
JADF
Yep, I have a 60 but above, oldusa says that the 63-67 kit fits with a 1/2 spacer. Can anyone confirm?
Old 10-02-2017, 12:04 PM   #13
oldusafmsgt
Old 10-02-2017, 12:06 PM   #14
oldusafmsgt
Those motor mounts will work, with a spacer on the top frame rail. The trans crossmember will need to be shortened, 60-62 frames are narrower than 63-66 frames. The headers I don’t know, I used factory exhaust manifolds.
Old 10-03-2017, 09:07 PM   #15
Old 62
Old 62's Avatar
I used some ebay weld in motor mounts in my 62 and made them bolt in for my 4.8 swap. Also made my own trans mount to fit between the x frame. Still running t-bars on drop spindles with disk brake. Used speed engineering shorty swap c10 headers with x pipe tucked into the t-bar cross member.
Old 62 is offline   Reply With Quote
