10-04-2017, 07:04 PM | #1 |
Is my way of thinking correct
I have a 72 c10 with a flip kit on rear. 2 1/2 drop spindles and 2” lowering big block springs. I do not want to drop the rear anymore I would prefer to raise the front some. My question is I measured the lip of the rear fender to center of rear center cap and it measured 16 1/2 I than measured lower lip of front fender to center of front center cap and it measured 15 1/4 am I corrrect in thinking if I switched to a 1” longer front spring that it it would be approx 1/4 lower in front . Thanks
10-04-2017, 08:13 PM | #2 |
Re: Is my way of thinking correct
a 1" longer spring in front will raise the truck ...not make it lower....
10-04-2017, 08:37 PM | #3 |
That is my intention. I want the truck to sit more level with less rake.
10-05-2017, 09:08 AM | #4 |
motor exploder
Yes, your thinking is correct. you would have a 1/4" rake from front to rear. It looks like your bed is sloping downwards toward the front of the truck (more that what your suspension rake is) - You might have to add/take away shims on the bed mounts to get it in line with the cab, that will help even out the 'rake' that you're looking for.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-05-2017, 10:05 AM | #5 |
Bosshogg thanks bringing the bed alignment to my attention. I just put the box back on with 4 bolts and used a rubber for a cushion between the frame and bed I’m going to take a look at this before I start swapping springs.
10-05-2017, 10:55 AM | #6 | |
motor exploder
Don't forget to post the before & after pics if you order new springs!
