Old 10-04-2017, 09:04 PM   #1
projectking
projectking's Avatar
Firewall pad
Wondering if a 71/72 pad is cut out for the cable throttle assembly, anyone have a pic?
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 10-04-2017, 09:11 PM   #2
projectking
Re: Firewall pad
I should add I'm installing the later pedal into my '68 to use with the Cummins
67 Chevy C10 LWB
90 Mustang Gt
Old 10-05-2017, 08:48 PM   #3
projectking
Re: Firewall pad
90+ views and no one with a 71/72?
67 Chevy C10 LWB
90 Mustang Gt
Old 10-06-2017, 09:40 AM   #4
dfwright
dfwright's Avatar
Re: Firewall pad
Interestingly enough, I took a bunch of pictures when deconstructing my truck, but none of the firewall pad itself. I do have some shots of the original pad in the background, when I was taking photos of the electrical wires and stuff under the dash, but I don't know if I got the area you need to see. The pad I have now is an aftermarket re-pop.
Let me know the general area you need to see, and I'll check if I have any pictures that happen to capture that area on the pad.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-06-2017, 10:29 AM   #5
projectking
Re: Firewall pad
Thanks, not even sure I'll need a pic.....is the pedal mounted on top of the pad? I searched but thanks to Photobucket it hasn't been too easy to see how it's installed!
67 Chevy C10 LWB
90 Mustang Gt
Old 10-06-2017, 10:55 AM   #6
dfwright
dfwright's Avatar
Re: Firewall pad
The triangular piece that the pedal pivots on is bolted over the pad. There are 3 little round holes in the pad for the bolts to go through.
Old 10-06-2017, 12:06 PM   #7
projectking
Re: Firewall pad
Right on, thanks for your help! It appeared that way based on the 3 raised holes on the plastic piece.....wanted to do it right the first time!
67 Chevy C10 LWB
90 Mustang Gt
Old 10-06-2017, 02:08 PM   #8
midniteblues
midniteblues's Avatar
Re: Firewall pad
Just be sure you get the correct year and you should be good. Only cause 67-68's have the sideways fuse box cutout.
Only problems I had with my 67 was the aftermarket plastic fasteners were way too tight to push through the oe holes, I ordered a set,and the pads came with a set and I ended up using oe rubber ones anyway since I didn't wanna drill
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
