10-12-2017, 07:38 AM | #1 |
Possible vapor lock problem
I have a 71 c10, 350 gm crate and motor with edelbrock 1406 carb. I run a Quick fuel electric pump with pressure regulator set at 5 1/2 psi. I have been experiencing pressure drops in the afternoons when its hot while in traffic. Once i start moving pressure goes back to normal. Would a return style revulator help with problem? Would running 93 octane help?
10-12-2017, 09:07 AM | #2 |
Re: Possible vapor lock problem
Heat soak problem maybe.
Do you have a heat spacer? |
10-12-2017, 09:11 AM | #3 |
Yes, I have a 1 inch plastic carb spacer.
10-12-2017, 09:14 AM | #4 |
My pump is inside framerail. Exhaust is routes outside framerail. Braided steel line routed from framerail straight up fire wall to regulator then to carb. Regulator is mounted almost level with carb
10-12-2017, 09:30 AM | #5 |
Is it a liquid filled gauge?
They go wacky with heat. Does it just keep running like normal when the pressure drops? |
10-12-2017, 10:16 AM | #6 |
No, gauge is autometer sport comp. Yes runs normal when pressure drops it hasnt shut down on me yet. I try to stay moving and limit time at idle
10-12-2017, 10:39 AM | #7 |
I guess you might try a return style reg.
Electric pumps don't like to be dead headed. |
10-12-2017, 10:52 AM | #8 |
I was trying to determine best course of action. Return style regulator or switch back to mechanical pump
10-12-2017, 08:11 PM | #9 |
Make sure that the fuel line isn't close to the headers.. I had that same problem.. we insulated the line where it was by the headers and stopped my vaporlock issue
