10-19-2017, 03:26 PM | #1 |
Need help ! 1962 c10 turn signal cable
Turn signals suddenly went out .. both on the dash and front and rear lights . I've checked to see if the cable is pulling/pushing the switch and it is not. If I activate the switch on the column manually everything works fine . So I'm guessing the cable isn't attached at the turn signal lever ??? Can this happen ? And would I have to remove the steering wheel to get at it . Thanks for any help guys .
Posted via Mobile Device |
10-19-2017, 04:35 PM | #2 |
Re: Need help ! 1962 c10 turn signal cable
Tommy,
Yes, you have to pop the steering wheel off. Underneath there you'll find a lever which activates the cable as you move the turn signal lever. The cable has a little loop which goes over the lever -- it's not inconceivable that this loop has just slipped off. I also found that the rivet which provides the pivot for my lever was loose, causing enough slop that the cable wouldn't move enough. Look at the switch and see if you can see any movement at all as you move the turn signal lever. It's possible the cable isn't moving enough (loose under the steering wheel) or that the cable isn't engaged to the switch any more (broken clip at the switch). B |
10-19-2017, 05:09 PM | #3 | |
10-20-2017, 04:39 PM | #4 |
It is possible to just muscle it off by pulling on it and rocking it back and forth, but not recommended. You should be able to barrow one form the auto parts store or buy one they are not that expensive. If you do try to muscle it off make sure you keep the bolt semi on the bolt a couple of threads so you do not brake your nose. Also make sure you take it off with the wheels strait or mark the wheel and the column some how so that you can put it back on straight.
10-21-2017, 09:32 AM | #5 |
I was having the same problem. Drop the steering column down and remove the wheel then you can get to it. I replaced mine a few times but it never worked right. I finally replaced the column and now it works perfectly!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
10-21-2017, 09:34 AM | #6 |
I know this is obvious but did you check the fuse? Usually, the simplest solution is the best one. With a sudden failure like you've experienced I would start there or look at some other power problem.
Maybe I'm missing something. What cable are you talking about? |
10-21-2017, 03:38 PM | #7 | |
10-21-2017, 10:11 PM | #8 | |
10-21-2017, 11:04 PM | #9 |
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
