Restoring it $200 at a time...
Door latch adjustment
I spent most of an afternoon getting the pass door adjusted nicely in the opening, with one minor problem. When the door is closed, it's very difficult to lock. With the door open, the mechanism is nice and smooth.
I'm pretty sure that the star wheel is stopping on a 1/2 tooth and interfering with the locking arm. Is there a way to clock the star wheel so that it's fully engaged with the striker? Since I'm happy with the door gaps, I'd rather not move the striker if I can help it. TIA Loren
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
#2 | |
The Older Generation
Re: Door latch adjustment
Only way to adjust that is to move the striker out. Did you lube all of the moving parts inside the door, and the star wheel? That may help if you haven't. If you roll the window down and use a good strong flashlight you can see the door latch & lock, and spray a little penetrating oil on the mechanism. If you decide to move the striker out be sure and mark around it with a fine felt tip pen and only move it about 1/16". Make sure it doesn't move up or down. LockDoc
Thanks Leon. I was afraid that moving the striker was my only option. Will try to find a balance between lock function and door adjustment.
LK
#4 | |
No problem, let us know how you come out on it.... LockDoc
![]() Join Date: Jul 2016
This question comes up frequently, I will explain the problem again...your door latch is worn.
Inside the latch on the same shaft is a latch wheel, it has teeth similar but square edged as the teeth you see on the outside of the latch. The door has a latch pawl that engages the hidden teeth and a separate lock pawl. The latch pawl wears along with the latch wheel which puts it out of synch with the lock pawl. You can remove the latch and grind some clearance into the lock pawl to correct the problem. I bought a truck with a set of repro door latches installed and they seem to work fine. |
#6 | |
Fortunately that is not always the problem as you seem to suggest. I always try the easiest solution before digging deeper into repairs. Moving a striker plate 1/16 of an inch is not a big deal compared to disassembling a door and removing the latch mechanism. That is why I always suggest it first. I asked him to let us know how that goes and if it doesn't work then is the time to dig deeper.... LockDoc
Latch wear is always the problem if the door is hard to lock when closed. You can create the same condition with the door open by placing force on the latch gear with your finger while trying to lock the door.
I have had this problem with the aftermarket latches.
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
And with new door seals, and after adjusting door fit. Many things can cause it....
LockDoc
#10 | |
I respectfully disagree..... LockDoc
#11 | |
For now, I've cocked the striker a few degrees. It'll lock now, but it's still kinda rough. I'll relieve the lock arm a touch when the door's apart for the new window rollers. Thanks guys.
