10-29-2017, 08:46 PM | #1 |
Steering box and rag joint questions
This came off my 71 2WD C-10. Current plan is to send it out to have it rebuilt. A couple questions per the captions in the images below, and input appreciated. Thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-29-2017, 09:35 PM | #2 |
Re: Steering box and rag joint questions
Checking some of my old notes, I think the shaft (#2) is called a worm shaft.
10-29-2017, 10:23 PM | #3 |
Get a oriellys rebuilt box, its lifetime guarantee. Get new rag joint assy from autozone number 200 or 201 cant remember
I BELIEVE IN JOHN 3:16 |
10-29-2017, 10:41 PM | #4 |
The Older Generation
#2 is the splined end of the worm shaft #3 is the ground wire for your steering shaft #4 is a keeper #5 is the housing top cover with the lash adjusting stud and lock nut LockDoc
10-29-2017, 11:18 PM | #5 | |
Go figure, the steering ground at the very bottom. I wouldn't have guessed, somehow. ...I suppose it's grounded where it mounts to the cab as well. Happy to say my "not sure" box only had 4-5 small pieces. Minus one, appreciate it.
10-30-2017, 12:14 AM | #6 |
Carpe manana
Ecklers also carriers replacement rag joints. I had my original steering box rebuilt by Red Head steering in WA. Does the date code on your box suggest its original?
10-30-2017, 11:03 AM | #7 | |
The top is stamped "119 71". Might mean 1/19/1971. The box is original alright. I took the truck to a mechanic before I bought it in 1989. He said the only thing wrong was the steering box leaked and needed a replacement. I never replaced it. Thanks for the lead. I don't see me rebuilding the rag joint. Honestly, the rubber on the old one looks great, but I figure new is called for. What the heck at this point. Brand new truck, someday, yikes. BTW, Red Head steering finish it for you? Out of a rattle can or gun? She's packed away, mostly clean.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-30-2017 at 11:57 AM. |
