Old 10-30-2017, 12:03 PM   #1
atotalnincompoop
Hydro boost swap
I have swapped a hydro boost system from a 99 gmc 2500 van into my 55 gmc pickup (4w disc setup). I purchased a disc/disc proportioning valve to run on the truck. I'm having issues with bleeding the brakes.
From what I've read the mastercylinder does not require a proportioning valve as the abs system handles that. however, since I am not using the abs system, I installed the proportioning valve.
Should I be running the prop valve on the original 99 gmc mc or should I swap in a different style nd and then run the prop valve?
Thnx☺
atotalnincompoop is offline   Reply With Quote
Old 10-30-2017, 02:21 PM   #2
Custom 68
Custom 68's Avatar
Re: Hydro boost swap
when I swapped mine I used the original style disk/drum proportioning valve. I would think either should work.
Just make sure you bench bleed the master cylinder (if new). I always start on right rear and do the left rear, them right front... I had heard to start the furthest from the cylinder.
Different method but did you get the air out of the hydro boost as well?
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-31-2017, 10:10 AM   #3
atotalnincompoop
Dave
I haven't even got to that yet. Hopefully will get this all sorted out today thnx
Old 10-30-2017, 10:02 PM   #4
68c10airstream
68c10airstream's Avatar
A couple suggestions that almost always help is this;
Jack the front or rear of the truck to level out the master cylinder. as an example gm cars in the 80's had a master cylinder that was pointed uphill in the front and would get air bound up in the front chamber and was impossible to bleed. i did many for friends that couldn't get fluid to move through the lines. I would remove the master cylinder lid and watch the fluid as someone else jacked up the rear to level the master out. About when level air bubbles would come up through the brake fluid, and then you could proceed to bleed.
The last suggestion is to NOT pump the brakes up frantically in between each bleeding cycle. What happens is air will be introduced from the back side of the master cylinder. The plunger that moves back and forth with your pedal effort has lip seals that are pointed forward (towards the fluid) and when you repeatedly pump the pedal the return motion can only seal against the bore by the residual tension of the lip. When you push down on the brake pedal the lip is forced against the bore and seals tight, but the return motion isn't forcing the lip to the bore, it's just dragging along for the ride. So pump slowly and also don't bottom the pedal out because you are going into a portion of the bore that typically isn't used. I've seen them stick to the floor a couple of times.
68c10airstream is offline   Reply With Quote
Old 10-31-2017, 10:13 AM   #5
atotalnincompoop
I try to take it slow, one of these days I'm going to invest in one of those reverse bleed pumps. I'll make sure the nd is level before I start today, good point thnx
Old 10-31-2017, 11:03 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hydroboosted cars need to be power bled, or bled while the truck is running since the reserve pressure cannistor only holds 2-3 "pumps" when the truck is off. Bleed the HB unit itself after install (bleeding the p/s side) with the wheels off the ground. Then bleed the actual brake system with the prop all the way open. After no air remains, set the prop.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
