Bracing cab prior to floor repair
Hello all,
I have a question about adding additional bracing prior to cutting out old floors, cab mounts, and floor supports. Are there specific locations that square tubing should be attached in order to keep the cab square when replacing panels? Is there anything wrong with using existing bolt holes and bolting the bracing in instead of welding it? I have searched the Internet to see how others have done it but it doesn't seem like any two people have done it the same. Is there a blue print out that shows the best locations to attach bracing? Any help would be greatly appreciated. Thanks Last edited by Grandpas 72; 10-30-2017 at 03:32 PM. Reason: Spelling |
Re: Bracing cab prior to floor repair
I wouldn't bolt it. It could move a tiny bit. I cross braced and welded, side to side and front to back. Once you cut the welds, they are very easy to clean up and you'll never see them when finished. I know the pix will load sideways, shot with an old cell phone... Sorry...
![]() Join Date: Oct 2014
Here's how I did mine. A pillar to A pillar, A pillar to B pillar, and across to other side and the same there. Then I welded 4 uprights to the floor so nothing could move. After I cut the rockers out nothing moved at all.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
Thanks for the pictures and advice! With the bracing in place, was there room to test fit the doors to check the gaps?
Thanks again! |
Weld the tubing on the inside of the pinch weld and the doors will close. And make sure the tubing is high enough off the floor, about a foot, so you can get your grinder/cut off and welder nozzle in there to do the repair.
Great!
Thanks again😀 |
