11-07-2017, 01:29 PM | #1 |
Cummins swap, I know there is a search button but the info is burried in many threads
I'm going to swap a cummins in my 72 crew cab.
The donor is a 93 W350 single rear wheel truck. I know the dana 60 front axle is just about a bolt in with axle pads 1/2" wider and a similar track width. I would use the dana 70 rear for the matching 3.55 gears, does anyone know the WMS width? I would use the stock dodge overdrive trans mated to the dodge NP 205, any known problems making this work? This is the info I am requesting. 1. Any front 4wd Differential clearance problems, I have a 2" lift or so. 2. Will the engine fit with the radiator in the stock location without firewall mods? 3. I know the Cummins is heavy so I assume frame reinforcement side to side is necessary which would probably be done with the engine mounting but has anyone used the stock cradle to mount the cummins? Can anyone point me to these problems in previous build threads along with any other obstacles? I don't want the install to languish, I want a quick install and on the road. Any help is appreciated! |
11-07-2017, 07:52 PM | #2 | |
6>8 Plugless........
Re: Cummins swap, I know there is a search button but the info is burried in many thr
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 11-07-2017 at 08:11 PM. |
11-07-2017, 09:56 PM | #3 |
Dieselwrencher, thank you so much, very helpful.
Damn, $7-$900 for a crossmember is a lot...Its doable but...can you point me to how you made yours or other nice ones? I will definitely use the spring shackles for mounting the front dana 60 if I do this. |
11-07-2017, 11:07 PM | #4 |
http://chevymotormounts.us/rob_bonne...ing_sets_6.htm
Contact him to see if he has anything for 67-72s. Here's a google search to show some pics. I can get you some of mine but they are buried in threads. Haha https://www.google.com/search?rlz=1C....0.5bs1UjkYhPY
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-11-2017, 10:38 PM | #5 |
I used the factory chevy motor mounts, and made my own buckets to fit them out of 1/4 plate. then cut out the lower crossmember and made a new lower one out of square tube. if you can build a crewcab door, you can handle this!
I have 4" exhaust, and just had to dimple it some around the edge of the transfer case so it didn't rattle.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
11-12-2017, 12:05 AM | #6 | |
Some things I noticed... The trans and transfer case is very long, should give a pretty good front driveshaft angle. The dodge radiator seems to be similar size to the chevy truck one and the inter cooler in front of it looks like it won’t be hard to mount in the chevy nose. |
11-12-2017, 08:17 PM | #7 |
the dodge mounts can separate, the chevy ones are encapsulated. thats why I used those.
12-07-2017, 12:48 AM | #8 |
I bought a Cummins donor today, 1995 2wd 5spd truck, 293k or so....didn’t want such high miles but did want The 5spd, it was advertised as a 96 which had me excited since those are 215hp, ended up being a 95, oh well. Runs good and no weird noises, trans is quiet and shifts very smooth. Bad power steering pump. Recently had the KDP fixed and a new front timing cover installed.
Anybody know why it might of needed a new front timing cover? Here is a pic of the beater...it was close by so I just went ahead and bought it, $3600 and he drove it home for me. It not a factory dually, it has adapters in the back and what appears to be factory hubs and rotors in the front. I’m gonna jack it up tomorrow and measure the width of the Dana 80, I think I can use it, problem is the tag says it’s 4:10 ratio, probably change that to something taller. It is posi though, at least the owner states that and the tag on the cover states the same. Changeover parts to convert the 5spd to mate up to my np205 are about $700. I will order that stuff tonight or tomorrow. |
12-07-2017, 01:50 AM | #9 |
Did it get a new gear housing or cover? The dowel pin usually takes a ride down to the cam gear and gets shoved out of the gear housing breaking it. I have a D80 in the back of my 72. These are about 4" wider than the HO52 if I remember right. Yeah, I'd be ditching the 4.10s unless you plan to run 35s. 3.54s are about ideal for these.
12-07-2017, 02:03 AM | #10 | |
If the dana 80 is 4 inches wider I wont be able to use it...I guess I will find out tomorrow when I measure it. |
12-07-2017, 05:08 PM | #11 | |
12-07-2017, 06:08 PM | #12 |
I’m not going to be able to measure the rear end today but found in pirate 4x that it should be about 69.5 wide which would make it about the same width as the front, might be usable, 4.1gesrs puts 65 mph rpm at 1850 rpm or so, I guess that would be ok, not ideal tho
12-07-2017, 06:38 PM | #13 | |
I saw in your thread that you have 33s. The NV4500 has an OD ratio of .73. So with 4.10s and 33s you're looking at 1981rpm@65mph. 2133@70, and 2286@75. Not horrible. Better than with 235s for sure. Haha
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 12-07-2017 at 06:49 PM. |
12-07-2017, 08:20 PM | #14 |
No problem. I didn't want you to be surprised when you got it together and was like WTH?
12-07-2017, 09:55 PM | #15 |
My shackle flip kit arrived today, I got it from off road design, ORD...very happy with it, these 68 frames have oddball rear spring widths and lengths and I don’t think they are available new, I got these springs from a 1990 or so 3/4 ton 4wd suburban, oddly the wheelbase worked out just right and the flip kit bolted right on using the old hangar rivet holes, super easy install.
12-08-2017, 06:05 PM | #16 |
Nice. ORD has nice products and great customer service too.
12-11-2017, 12:02 PM | #17 |
Have some turbo questions....
Clearly my engine is not running at its potential, i haven’t run it hard because there is no heater so the windows are always foggy and there is no power steering. Has great power till about 21 or 2200 rpm, makes about 17lbs of boost in that range and before. Maybe it makes more boost and more power at higher rpm, I don’t know because I’ve only driven it on side streets and the foggy window provlem. I looked in the cold side of the turbo and the blades are full of nicks, the outer edge appears to be worn, it’s dirty and there is some play side to side. I haven’t looked at the hot side yet. Should I rebuild this turbo with a new shaft and wheels? Is the core usually rebuildable? Should I buy a new center section already assembled? Or is the condition Normal for used and should I just run it like it is? Another thing, how hard is it to remove the injectors and what does it cost for new seals etc, if I do that? I have the $900 OTC diesel injector tester, I was considering pulling the injectors to check the condition while I have the engine out. Does anyone know if the Cummins injector will screw into he OTC tester without an adapter? I only used it once on some injectors from a sailboat, unsure of what engine was in the sailboat, |
12-11-2017, 03:20 PM | #18 | |
You can really sink a lot of money into a torn up turbo in a hurry if you aren't careful. Most places on the net are pushing China parts too and it's hard to know what you're getting. I've been putting a lot of these on trucks for guys lately with great luck. I am a dealer for them as well. Between the price of a turbine, comp wheel, rebuild kit, and the time of removing broken bolts from the exhaust housing, a rebuilt turbo is the way to go IMO. https://areadieselservice.com/diesel...oduct/70-4005/ There are several different aftermarket ones but are more money and you don't really need one if you don't plan to make over 400hp. The injectors aren't bad to remove. They can be stuck in the head. You can make your own puller with a short piece of tube, and a lug nut from a srw 94-02 dodge. Here's a link to a new one. https://puredieselpower.com/dodge-pr...or-puller.html I have the snap-on one that has different ends. This won't work on cylinders 5 and 6 though due to the cowl over hang. To remove the injectors, you just remove the injection lines, return line, and then use a 15/16" socket to remove or loosen the hold down nut. Then pull the injectors out. You'll probably need an adapter for the OTC tester. Did yours only come with one line? The sealing washers vary on price. If you did have a 215 they are a thin washer. I can get you a price on injectors and any cummins parts you need too. Or, Puredieselpower is a great source as well.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 12-11-2017 at 03:30 PM. |
12-11-2017, 03:33 PM | #19 |
Have you rebuilt any turbo's? Any thoughts on how to get it done per my post?
Thanks for the info on the injector puller, I can make one of those. I guess if I'm getting 17 pounds of boost and thats stock then I will do the turbo a bit later. I just bought a low side fuel pressure gauge and a EGT gauge, I think I will install it and see what the numbers are....maybe check the injectors with the engine out. |
12-11-2017, 03:49 PM | #20 |
Randy, I've rebuilt many of them. Around here the rust and corrosion make it really hard to justify me rebuilding a turbo unless it's mine. Turbo rebuild facilities have special ovens they shove the cores in to rip them apart with less likelihood of breaking bolts and getting the housings off without ruining them. I don't have that and after the last 3 breaking every bolt off in the exhaust housing, I've had enough.
If yours has an HX35w, there are 4 bolts you have to remove to get the retaining clamps off so you can remove the center section from the exhaust housing. Most times you have to heat the exhaust housing to get the center section off. Once you have the center out, place the center section in a vice and remove the comp housing. It has a very large snap ring that holds the compressor housing to the center section. Use large pliers or a huge snap ring pliers to remove it. Sometimes you will need to rap on the snap ring ears to get it to break loose. Be careful, they bite! You can use a small dead blow and tap side to side from the back to help break it loose. Be careful not to get the housing too cocked while doing this or you can damage the comp housing/wheel and or bend the turbine shaft. Once that is off you can remove the nut off the turbine shaft and remove the turbine form the center section. Then there is a snap ring to remove the thrust plate and there are other small snap rings holding the bushings in the center section. Sometimes you get lucky and they come right apart. Very doubtful though. Haha Make sure your low pressure fuel gauge has a snubber in it other wise your needle will bounce.
12-11-2017, 04:12 PM | #21 |
Ok, I figured taking apart the turbo was iffy...Now it's confirmed.
I did buy the snubbed but read mixed reports on whether they work right... |
12-11-2017, 04:27 PM | #22 |
By the looks of the engine pic on your other thread, is the compressor cover retained with a clamp?
12-11-2017, 05:40 PM | #23 |
12-12-2017, 11:15 AM | #24 |
It is the housing on the front of the turbo. It houses the compressor wheel. The H1C model uses a large clamp to hold the compressor housing to the center section. Where a hx35 uses the large snap ring.
12-14-2017, 03:31 PM | #25 |
New question dieselwrencher....or if anyone else knows, chime in...
I'm looking at a 2017 6.7 engine, the engine mounts appear to be different, maybe 2 per side, can you fit the 95 mounts/brackets to the newer engine? and thoughts on wiring the 2017 up? I would think its not much different than any common rail, some battery inputs, key on, start input and some grounds... |
