11-08-2017, 01:11 AM | #1 |
dual electric fans question(s)
In an attempt to complete my mockup of everything in front of the motor I am now looking at cooling fans. As said I already have the VA Front Runner system to bolt on the 350 Ramjet I am planning on getting in the spring. It has the upgraded 170 watt alternator.
I am somewhat limited with room as I really do not want to move the engine back. I have just spent a considerable amount of time searching fans on this forum and on the inter-web. As usual there is lots of conflicting information. My question is: Using the US Radiator copper 4 core high efficiency crossflow rad how many CFM's of air do I need to keep things cool? The Flex-a Lite low profile fans that I am looking at are 2 5/8 inches thick and will fit nicely. They are rated at ca. 2500 cfm! Is 2500 cfm going to be enough to cool the 350 Ramjet? I live in southwestern Alberta and we might only see a few days approaching 100 degrees above and the climate is quit dry, although last summer was the exception. Thanks in advance for again sharing your knowledge on this and the many other challenges that I am facing. |
11-08-2017, 10:57 AM | #2 |
Hollister Road Co.
Re: dual electric fans question(s)
Start with what truck this is?
There are many theories on what's best for cooling, 4 core with a mechanical fan to 2 core with a hi performance electric. Cooling depends more on how much heat the radiator will release than CFM passing through it, CFM depends on fan capabilities and can the air get out of the fan efficiently. You look at the back of a high dollar Zirgo that claims 3000 cfm and you wonder how it could possibly pass any air at that CFM while you look at the back of a Taurus or Thunderbird fans rated at approx 2300-2500 CFM and think a hurricane could blow through these fans why is it only 2500. What radiator type? Cross flow, the old type down flow or a split core. Brass or aluminum. I prefer brass, The physics are better for heat transfer. How do you want to control it? Do you want relays or Pulse width control? can it be controlled by a PCM , If yes does the PCM have hi/lo fan options? Prefer single fan or dual or just whatever will fit? Do you plan on running AC? What HP does it have? Flex-lite would not be my first choice, OEM if you can get it to fit such as Thunderbird or Taurus or Camaro, Spal Low profile fans are usually under 1800 cfm so i would question the 2500 rating what ever fan you choose it needs to have 80% radiator coverage, either in a single fan or a dual or multiple fans, I ran 4 9" fans to get 4000 cfm cooling a 468 BBC here in Texas in 100 degree weather, It looked odd it was a bit loud but it worked and got by all the engine obstacles. |
11-08-2017, 12:41 PM | #3 | |
The truck is a 1956 Task Force that I have sitting on a shortened 1980 1/2 ton frame. I am planning on a 350 Ramjet that is rated at 350 horse and 400 foot pounds. My radiator is a US Radiator copper/brass crossflow with what they call an 80's style core with 1/2 inch tubes on 3/8 inch centres and is a 4 row which makes it 2 5/8 inchs thick. The core measures 24 1/2 X 17 1/2. The radiator does not have the automatic trany cooling function so will be cooled by a remote trany cooler that I have purchased on the advice of my trany rebuilder guy- a reputable shop in a nearby city. The fan I am looking at, so far mainly because it will fit, is a Flex-a-lite dual 12 1/8 Lo-Profile s-blade with variable speed controller. It measures 26.25 X 15.5 inches and is 2 5/8 inches thick. It is rated at 2500 cfm. Yes I will have AC. As said the dual fans I am looking at are controlled by a variable speed controller but I am certainly open to all suggestions. Not sure if I answered all your very good questions so feel free to fire back. Being a builder from Texas I am sure you have lots of knowledge on all things related to cooling our trucks. I really appreciate your response. I am also open to your suggestions as I have not ordered the fans yet. I will look at Spall. There is also a slight chance that I could gain another inch by getting some Dirty Dingo engine mount sliders but would have to put my cab back on the frame and see how much room I have. I really do not want to have to cut into the firewall to create more room. I still have the mock up engine and 700r4 trany sitting in the frame. That extra inch might allow me to go with fans that are thicker and have higher cfm ratings. |
11-08-2017, 11:50 AM | #4 |
I used a Spal pusher on mine, if I recall it’s rated at 3500cfm. With a Northern aluminum radiator and a Milodon high flow water pump my mild 454 stays around 180 in stop and go traffic
11-08-2017, 12:52 PM | #5 |
Thanks for your response. I have absolutely no room for a pusher as I have the trany cooler mounted up front.
11-08-2017, 01:37 PM | #6 | |
Hollister Road Co.
I don't know about their control, if its variable then it's most likely a pulse width modulated unit but you can google flex-a-lite pwm problems or flex-a-lite variable control problems and see what pops up. All units have some issues no matter who's making them so if it's only a few then it's most likely an ok unit. Most issues with PWM units is the installer or the buyer trying to drive a fan that over its capacity, ie a 40 amp PWM trying to drive a Mark 8 fan. or the installer connecting it up backwards With relays controls we typically control the hot side of the circuit, with PWM we control the ground side so for those of us that don't read instruction we hook it up backwards and cook the circuitry and blame the control. Pros to PWM are sped rams up as needed making the fan quieter in most cases. depending on how and where their reading the temp, usually at the lower rad outlet return, it only runs when the radiator is hot so if you're on the highway the rad is cool the fan will not come on. They are adjustable to your normal temp providing you have a Tstat lower that the temp you want to run. Cons are they some time have a low speed clicking or buzzing, starting the fan below 50%, spal and flex-a-lite eliminate this by starting the fan at 60% power. They are often time more expensive and not as reliable as a good old really. They are sensitive to other PWM devices in the car and can cause disturbances between the units unless you shield them. Pros for relays. you can get a replacement at any parts house. Time tested part, usually very inexpensive. Cons, the fan or device is either on or off no inbetween. The temp sensors are usually in the block or Tstat housing so it the engine is at say 185F the fan comes on whether you at highway speed or not. |
11-08-2017, 02:59 PM | #7 | |
Flex-a-lite also lists an adjustable thermostatic controller! Is that any better than the variable speed controller? Or are they two different things. As you can tell I know nothing about this sort of stuff. It looks like there may be options for controlling whatever fans I get and I really don't have to make any decisions on that front yet although it is good to plan ahead. Up until a few years ago I never even had AC in my personal vehicles!!! My wife has for ever but my old trucks never... |
11-08-2017, 04:53 PM | #8 |
56, I got the dual 11" inch SPAL puller fans w/aluminum shroud for my aluminum U.S. Radiator cross flow in the 57. Haven't run it yet, but Jim at U.S. Rad said it should be plenty to keep my 383 Stroker cool. I believe they only extend around 2.5" from radiator.
Cheers, Jim |
11-08-2017, 06:20 PM | #9 | |
Hollister Road Co.
Some of the adjustables have a big probe you push into the radiator fins to pick up the temp. It's a better place to read temperatures but the device is a hot water heater thermostat somebody figured out could be used for cars. There are digital adjustables but again it's an ON OFF device. Ac makes a difference. You want the fan to come on full speed when the compressor engages so you don't pop a compressor head due to pressure build up and excess heat. |
11-08-2017, 01:21 PM | #10 |
congrats on the ramjet 350, best part i ever bolted into truk, a little pricey but well worth it
every spring i turn the key and it starts right up after sitting all winter you should have lots of room for any fan/radiator setup i have 3'' or 4'' between the fan and water pump can't help you with part numbers, i have a stock looking us radiator 4 row desert cooler with trans cooler built in i bought the us radiator shroud with 16'' spal puller fan from us radiator having the shroud to cover most of the core is very important, wire tying a fan to the rad is not good for air flow
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-08-2017, 01:31 PM | #11 |
i used the running sbc that came in truk to mock up motor/trans mounts
i had to modify the firewall a tad due to the huge plug coming off the back of the distributor on the ramjet 350 also modified the mefi controller and coil brackets from the back of the motor to over the valve covers
11-08-2017, 02:39 PM | #12 | |
I have been doing my mockup with a 283 with its stock distributor. I am most interested in what you have said regarding the"huge plug coming off the back of the distributor" and your "modification of the mefi controller and coil brackets." I am thinking that I need to put the cab back on the frame to see how much room I have back there and if I will need to do the same. Modifying the firewall has always scared me but I like the looks of yours! Do you have any idea of how much farther the "huge plug" sticks out as compared to the stock distributor? Also did you have to modify the mefi controller and coil brackets because of space available back there or because you just wanted to move? |
11-09-2017, 02:12 PM | #13 | |
the mefi controller and coil brackets are designed to mount on the back of the each head. doesn't work on our trucks. yeah you need to throw the cab on to check the fit. both fuel lines exit on back near the same area too. you can see the supply line up front and the return regulator behind the distributor in this pic. i had the stock front motor mounts on the sbc when i fabbed the motor and trans mounts. my motor is in the stock location for a v8. if you winter anywhere near sarasota fl, look me up. i'll be heading down after xmas heading south for you could be kalispell montana
11-10-2017, 11:24 PM | #14 | |
Again the 56 body sitting on the 80 1/2 tone frame present a few new challenges. I never knew about the plug on the distributor until you mentioned it and thought I was going to be okay after my original mockup. I also never knew where the Mefi was sitting and know it also not work for me not he back of the head. Cant wait to get the cab sitting back on the frame to tackle those little issues. Your right Kalispell is just a hop, skip and a jump from where I live in the southwestern corner of Alberta but we winter in Arizona. |
11-11-2017, 11:01 AM | #15 |
Here's my preferred method for controlling dual electric fans:
http://67-72chevytrucks.com/vboard/s...83#post7621383 Here's the diagram I drew up for how to wire: L and H wires go to the Dakota PAC-2750 controller and the A/C uses a trinary switch that also has a wire feed to the Dakota Controller. Relays are weather sealed and all connections are crimped, soldered and covered with adhesive lined heat shrink tubing. I also use Midi/AMI fuse blocks with screw down fuses. |
12-11-2017, 10:53 PM | #16 | |
It looks like I have just over 2 inches of room back there. If I had to I could gain another 1/4 to 3/8th but it would require removing a small "raised" strip on the firewall. Not sure about the "indexing" the distributor to help this as I do not know what that really means. Do you think the full 2 inches of room behind my current distributor is going to be enough? I will try to get a picture tomorrow. Thanks in advance. |
12-11-2017, 11:42 PM | #17 |
just try to get the cap on and off a few times. that will tell you. the"indexing" thing is about the positioning of the dist. base. you still need to allow room to turn the base to adjust the timing, if it fits and is adjustable enough without hitting the firewall then you have it made.
11-09-2017, 02:06 AM | #18 |
This may work for you a 2000 Camero rad and fans.
Way less $$$ then aftermarket stuff .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
11-16-2017, 03:33 PM | #19 |
us radiator has a pretty ingenious method for making fan shrouds
they have a press die for doing the formed corners of any flat plate i believe they have the shroud laser cut, press the corners and then bend the edges to match then they weld mount tabs on to the shroud first time around the shroud they sent me had the tabs welded on the wrong edges didn't work to well with top/bottom tabs on a stock radiator one other thing on the ramjet 350 install: the main harness is 1'' in diameter the main relay, fuel pump relay and 6 wires are on the end of this harness off the top of my head they are: main power, ground, ignition, fuel pump, digital tach and analog tach because of the relay sockets you can't feed the harness thru a grommet the firewall mod behind the distributor has a removable back on it i cut a half hole in the cover and base to accept the wiring harness i used a grommet that is cut to go over the flex condiut
11-16-2017, 06:47 PM | #20 |
Hey Ogre that's pretty cool about US Radiator. Jim was great to deal with and I know he went back and forth with Production to figure my project out.
I was wondering about my wiring as I had just pulled my American Autowire harness out when I was mocking in my Evaporator. The AAW fuse box uses the inside of the two drivers side hood hinge bolt to fasten! That is ingenious! Regarding your electrical comments. That is pure genius in my opinion and I am going to copy you!!!! Remember imitation is the most sincere form of flattery... I have left one large tapered hole open on the firewall above th fuse box. I was planning on running the engine compartment wires through it but was unsure about the EFI harness. I know many people have moved the little computer on top of the 350 Ramjet engine but putting it behind that little firewall recess is a great idea. So your computer is inside right? Good ideas all. Just finished priming, seam sealing and undercoating the under side of the cab and inner front fenders with Eastwood products. Turned out pretty good and I will get some pictures next time I am out in the shop. |
11-17-2017, 03:21 PM | #21 |
best pic i could find of the inside of the distributor box, lots of wires for: power window switches in console, stereo with 4 speakers and amps behind the seat, alarm system/remote entry/door switches, trunk and tonneau cover switches and cruise control module all stuck in the bottom of the console. all the ramjet wiring is on top of that mess.
11-17-2017, 04:26 PM | #22 |
i wanted the firewall bare with no visible wiring exposed
i used the hinge bolts and 2 bolts thru the the floor rear lighting exits under the fuse box below the angle floor pan front lights follow the heater/ac hoses in grey flex on the right side of the cab
11-18-2017, 11:35 AM | #23 |
Hey Ogre do you have any pictures of how you created that firewall modification to accommodate the distributor module?
I am getting ready to put the cab back on the frame and want to see what I am up against! I am also not too worried about hiding all the wiring in the engine compartment but would like to put the ramjet computer on the inside and your mod could help in that department. Thanks in advance. |
11-18-2017, 12:31 PM | #24 |
while anything is possible i think that you would have to modify the ramjet harness to get the controller inside the cab
i don't have any fabrication pics just use the pics i have posted to make the box approx 7'' wide, starts above the distributor cap and goes straight down the 3 pics above pretty well show the construction and the size of the removable panel this 2nd to last pic shows the ramjet harness with relays and the back of the distributor modification also note the slight mod to the trans cover to get the 700r4 clearance last pic has some of the layout lines for the cutout back in the ugly stages of my build
11-18-2017, 02:38 PM | #25 |
Ya I really don't want to have to modify the harness for the controller. That's way too scarey for my little pea- brain!!!
Is that your controller sitting at the back on the drivers side of the engine? The last picture showing the firewall modification helped a lot. I had no idea what it did down low! That looks doable! I had a TH400 in for my previous mockup and now have the 700r4 sitting in there. I am thinking or thought I heard that there was little difference in physical size between the two. Don't forget I have the body sitting on a 1980 1/2 ton frame. My boy should be back next week to help me put the cab back on the frame. Then I will know. Thanks a ton for your continued input. I know I will have more questions on the engine and trany hookup when I get down to that. |
