Old 10-30-2003, 01:38 AM   #1
orange72350
orange72350's Avatar
Stupid Engine mounts.,
I just dropped my 350/350 combo back into my 72 gmc. no matter what i try these stupid engine mounts will not line up on the towers. the tranny is perfectly mounted, and the engine is close, but the left side needs to come forward 1/2 inch, and the right needs to go back 1/2 inch. what is the easiest way to line this up? im almost to the point of unbolting the bellhousing almost all the way and moving the engine till it lines up, then retourquing everything. any suggestions are greatly appreciated.
thanx
dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 10-30-2003, 02:06 AM   #2
Alexis
Member since 2000
Alexis's Avatar
losen up the towers. and unbolt the transmission. Once you got the thread running on the engine mounts, tighten it up. Align the transmission and get the bolts in it and then tighten up the rest. Hope it helps
Alexis is offline   Reply With Quote
Old 10-30-2003, 02:18 AM   #3
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
what he said
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 10-30-2003, 09:44 AM   #4
Blue Beard
Blue Beard's Avatar
Use an alignment bar to help.......
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-30-2003, 10:03 AM   #5
Huck
Huck's Avatar
Have seen this happen, make sure you have the engine SBC mounts on the correct sides---left/right as this can really screw things up.
Huck is offline   Reply With Quote
Old 10-30-2003, 10:55 AM   #6
COBALT
COBALT's Avatar
I unbolted the towers completely from the frame, bolted them to the mounts on the engine, and use some bar stock as guide studs to force the towers back into place. Then I installed the remaining two bolts on each tower, and knocked the guide studs out, and then put the remaining bolts in.
That was after farting around for 2 hours trying to loosen everything on my truck to get the damn holes to line up...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-30-2003, 03:58 PM   #7
orange72350
woo hoo. sounds like i got a fun night planned. (sarcasm) These mounts can really be a pig to line up. How can u tell left from right? they both came in the same style box, with no marking, so i just figured they were the same. thanx
dale
Old 10-30-2003, 05:13 PM   #8
fast67chevy2002
Dad's little helper
fast67chevy2002's Avatar
I would like to know how to tell also, thanks.
too many projects:
61 biscane
67 swb(shaved)
73 Fiat spider 124 Sport
84 Pontiac Grand Prix
86 olds cut. sup.
fast67chevy2002 is offline   Reply With Quote
Old 10-30-2003, 08:08 PM   #9
crazy longhorn
Fabricate till you "puke"
The mounts are the same part # for both sides.....I think Huck was refering to the frame stands. those mounts are a PITA to line up......the last 3 trucks I have done have had the center holr in the frame stand drilled to 5/8 ", to give a little room to work with. They bolt in much easier, & the extra material removed doesnt hurt a thing(that 7/16 bolt has a thick flatwasher on it). Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-30-2003, 11:43 PM   #10
junkyardjohn
junkyardjohn's Avatar
I JUST PUT A MOTOR IN MY 69 1 TON TOWTRUCK. WHAT A PAIN GETTING THE TOWERS TO BOLT UP TO THE MOUNTS. AFTER SCREWING WITH TRYING TO GET THE BOLTS STARTED FOR ABOUT 4 HOURS, I FINALLY REMOVED 1 OF THE MOTOR MOUNTS & FOUND THAT THE THEADED HOLE WAS ABOUT 1/4" HIGHER THAT THE OEM ONES. THEY WERE ANCHOR MOUNTS THAT WERE MADE IN INDIA. (WHAT DO A BUNCH OF INDIAN GUYS KNOW ABOUT 67-72 CHEVY TRUCK MOTOR MOUNTS ANYWAY??) I BET THERES NOT 3 67-72 TRUCKS IN ALL OF INDIA. I TOOK THOSE BACK, & WENT ON A QUEST OF ALL THE AUTO PARTS STORES IN TOWN TO TRY & FIND SOME MOUNTS THAT WERE CLOSER TO THE ORIGINAL ONES. ANYWAYS I SETTLED FOR SOME THAT WERE CLOSER TO MY OEM ONES , BUT STILL HAD TO GRIND ON THEM,LOOSEN UP MY TRANNY,LOOSEN MY FRAME TOWERS, DRAW THE MOTOR DOWN DEEPER IN THE FRAME WITH A BIG C CLAMP & PRY ON IT WITH A 3 FOOT PRY BAR. GOOD LUCK JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-31-2003, 01:02 AM   #11
zork
I just put new mounts in my k20 last week and I had to lossen the trans mount and engine cross section . I also had to jack the tans to one side. That was after cutting a little piece out of the india motor mount to get the lower bolt in the block. It took me 3 hours to get everything lined up.
It will be worth the effort when you are done! Good luck!
Zork.
zork is offline   Reply With Quote
Old 10-31-2003, 02:23 AM   #12
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
We just put in our rebuilt big-block in the Longhorn......Patience..PatiencePatience ..and a big crowbar
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 10-31-2003, 11:48 AM   #13
frost89434
frost89434's Avatar
They can be a pain in the arse!!! Like everyone else said. Pateince.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
