Spakers instead of kick panel vents
I am planning on installing spakers where the kick panel vents are. I love having the vents but when installing a vintage air ac you can no longer keep the passenger side vent. Sense I will be installing an ac I figured I will not need the vents. So my question is if I install the spakers instead of the vents how do I keep the back of the speakers from getting wet when it rains? The truck has already been painted so I don’t want to weld the cal vents shut. I am going to put phome cups on the back of the speakers and was thinking of using thick plastic and liquid gasket to keep the water off.
![]() Join Date: Sep 2006
Re: Spakers instead of kick panel vents
Unbolt the vent frames from the cab and remove the doors. You can seal off the back with some kind of material. I think I used plexiglass and some kind of glue. It was 17 years ago I don't remember. I know I used plexiglass for the face after drilling the screw holes out and then bolting them back on. The speaker wires can run out from under or no top of the vent frames. You can make a notch so you don't pinch the wires and just bolt them back on.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Turning Wrenches Daily
see post 279 onwards in my thread I did same thing and sealed the back with 1/4 inch abs plastic paneling
![]() http://67-72chevytrucks.com/vboard/s...438342&page=12 Sean Wolff
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!! 1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342 2016 Ram Big Horn 4WD parts hauler 2010 Chevy HHR wife new car after the circled problem blew up!!! 1981 Ram D150 /6 auto Wife's sunday driver Living outside Gladewater Texas now working in Longview at the hospital there future project toys: 1966 Chevy K14 carryall aka Smurfette future project ![]() |
