Old 11-13-2017, 05:58 PM   #1
Haru
Haru's Avatar
Dash lights issue 71 C10
I've read many threads to go about correcting the turn signal indicators being on. This Used to only be when the headlights are on. Now they are always on. The main issue now is when I turn on the AC/Heater switch (the vertical one) It's turning my dash light on, any advice?
-71 C10 long bed, 402
-91 Camaro Z28, B2L 350
-96 Tahoe 2 door 2wd
-15 Tahoe LT
-16 Lexus RC 350 F sport
Haru is offline   Reply With Quote
Old 11-13-2017, 06:08 PM   #2
demian5
demian5's Avatar
Re: Dash lights issue 71 C10
Run a separate ground between the back of the cluster and the firewall.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-13-2017, 06:17 PM   #3
Haru
Haru's Avatar
I'll give that a shot, thank you!
-15 Tahoe LT
Old 11-14-2017, 07:20 AM   #4
randy.powell
Check/clean ALL grounds. There are 5 of them. Even if you run a ground from the cluster to the firewall (should be one there already) if the cab doesn't have a good ground to the frame you have nothing. The cab is mounted to the frame with those big rubber mounts which are excellent insulators...
Randy
randy.powell is offline   Reply With Quote
Old 11-14-2017, 05:02 PM   #5
Haru
Haru's Avatar
Randy
Thank you, I will check it out!
-15 Tahoe LT
Old 11-14-2017, 07:04 PM   #6
Myoldtruck
Myoldtruck's Avatar
I read about this awhile back, right after i bought my truck. I Grounded my bed to frame and cab to the frame using no.6 wire
Myoldtruck is offline   Reply With Quote
