11-14-2017, 10:33 AM | #1 |
AD Tire Size
Current I'm running a 255/35r20 on my 1950 AD but want to swap them out for some 15" wheels. Am leaning towards the 205/75r15. Truck has a MII and ford 8.8 rearend with air ride. Also guys who are running white walls what size white wall did you go with 2 3/8" or 3" white wall
11-14-2017, 11:08 PM | #2 |
Re: AD Tire Size
I went with 15x7 205/70-15 (26-1/2" diameter) on the front and 15x8 225/70-15 (28" diameter) rear. The decision was dictated largely by practicality and economics: as soon as you go to the larger diameters and lower profiles the cost goes up exponentially.
The big whitewalls always look better, imo. Curious: why do you want to go to the smaller wheel - going retro? |
11-15-2017, 01:03 AM | #3 |
Re: AD Tire Size
I tried a set of 6.70 bias plys for fun and liked the look. I am trying to go a little retro with it but now that you say it I may go with a 215/70r15 which is a little smaller than what I have now with 20's. My next issue is finding wheels with the right backspacing
11-15-2017, 03:38 AM | #4 | |
Re: AD Tire Size
11-15-2017, 02:13 PM | #5 |
Re: AD Tire Size
Definitely need to check on your caliper/disc size. I have 11" brakes and cannot fit 15 inch rims.
'51 Chevy 3100 Short-bed 2000 Custom Ducati Monster 900ie |
11-15-2017, 09:10 PM | #6 | |
Re: AD Tire Size
for wheels if you want steelies with caps look at wheelvintiques.com you can get any size or backspace
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-20-2017, 09:08 AM | #7 | |
Re: AD Tire Size
Mounted on 15x8 artillery wheels |
11-22-2017, 03:33 PM | #8 |
Re: AD Tire Size
I kind of like the factory look, what size could get me in that ballpark?
1950 Build |
11-15-2017, 09:29 PM | #9 |
Re: AD Tire Size
Laid out what kind of wheels do you have now ? ill be in the Market son and might go bigger still haven't decided
11-15-2017, 09:44 PM | #10 |
Re: AD Tire Size
Currently I'm running 20" Dodge Steel wheels on a 255/35-r20 and aired out the running boards sit about an inch off the ground. I didn't want them to touch the ground in case an airbag pops I can still drive even if in straight line
11-20-2017, 01:04 AM | #11 |
Re: AD Tire Size
I went with 205/75R15 on my '50 and thought I liked them. Then while doing some serious digging into tire size for my '47 I ended up finding some 215/75R16 and really wish I had gone that route on my '50. Much taller tire but still pretty narrow for a stock look. If you already have 15" rims I'd go with the 205/75, but if you're buying a new set I'd seriously consider some 16's.
11-24-2017, 11:29 PM | #12 |
Re: AD Tire Size
The 215-75-15 fit the wheel wells pretty nicely most of the time.
I ran 14x7 inch wheels with 11 inch Camaro disk brakes so I don't see where he clearance issue would be unless a guy ran old drum brake wheels.
