Old 11-15-2017, 08:27 PM   #1
tinydb84
tinydb84's Avatar
Rear suspension rework
A guy through instagram contacted me about redoing his rear suspension. It was a local shop truck he picked up and didn't realize how bad the suspension was. I don't think I am going to do much more than the rear on the truck so I'm not going to start a project thread on it but the pictures are pretty cool so I figured I'd share. I tried to bang it out in a weekend with his help but it is taking a bit longer than originally planned. Hopefully should be done by this weekend.
Here is the truck:
And here are the problems
All the suspension tabs were 1/8'' thick, bent, and cracked.
Piles of parts...Check out that panhard bar, 2 link, and offset bag mounts.
And they welded the two link to the axle perches, which were welded on one inch off to the side.
David
Instagram: myfabguy
Old 11-15-2017, 08:27 PM   #2
tinydb84
tinydb84's Avatar
Re: Rear suspension rework
Then I noticed they didn't weld up one side of the notch. It clearly wasn't prepped to be welded so we ground off one of the welds.
and we have no penetration
I'll be grinding out a grove to weld it properly.
David
Instagram: myfabguy
Old 11-15-2017, 08:28 PM   #3
tinydb84
tinydb84's Avatar
Removed all the offending areas.
Bought a universal 3 link from AVS. Nice product! Decided to run a bag on bar set up so I welded on the trusses.
Welded on the axle tabs
20171111_133809
Welded the tabs to the differential. Preheated, used nickel rod, and peened it with an air chisel. That's why the weld looks so odd.
David
Instagram: myfabguy
Old 11-15-2017, 08:29 PM   #4
tinydb84
tinydb84's Avatar
On to the frame side
Tabs on
Suspension in!
David
Instagram: myfabguy
Old 11-16-2017, 09:16 AM   #5
JohnJ@RideTech
JohnJ@RideTech's Avatar
Nice! Glad to see you got it all straightened out. No doubt that original install was a little sketchy and unsafe. Good job!
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 11-17-2017, 02:31 PM   #6
bs46488
Nice looking fix. Those are much nicer looking welds!
It's scary to think that an actual "shop" was responsible for the original suspension design.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
Old 11-20-2017, 01:27 PM   #7
tinydb84
tinydb84's Avatar
Fixed all the notches
David
Instagram: myfabguy
Old 11-20-2017, 01:31 PM   #8
tinydb84
tinydb84's Avatar
I had originally planned on doing bag over bar for this set up but the original builder welded the notches in funky (and not in the same spots...) so I didn't have enough space to fit the bags on the bars.
Ended up with a bag over axle set up.
David
Instagram: myfabguy
Old 11-20-2017, 01:33 PM   #9
tinydb84
tinydb84's Avatar
I didn't want to build a bridge over the axle so I decided to weld the tabs to the pumpkin. I bought some Nickel99 rod (holy **** that's expensive). Preheated the housing, welded it with the nickel rod, and peened it with an air hammer as it cooled. No cracks! It should hold up just fine but if it ever cracks Ill build a bridge and fix it.
David
Instagram: myfabguy
Old 11-20-2017, 01:40 PM   #10
tinydb84
tinydb84's Avatar
Mounted the shocks to the upper bag mounts and ran them off the bars to make sure there was enough travel.
Ran a cross member along the backside to tie to the bag mounts.
and the finished product
David
Instagram: myfabguy
Old 11-20-2017, 01:45 PM   #11
DieselSJ
Noob welder question - what is the purpose of peening the welds? I don't think I have ever seen that done.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 11-20-2017, 01:53 PM   #12
tinydb84
tinydb84's Avatar
Thank you sir. He has a young daughter he wants to drive with so that old work had to go.
Just to clarify, the shop he got it from didn't do the work. They just painted a logo on it and drove it around. The original bag job was done in Texas. Not sure by who though.
It is done as the welds cool in order do decrease the stress and reduce the likelihood of the welds cracking. Mild and cast steel have different cooling rates and it is really common for welds on cast steel to crack.
David
Instagram: myfabguy
Old 11-21-2017, 12:28 PM   #13
DieselSJ
Well I learned something today. Thank you.
Old 11-21-2017, 05:07 PM   #14
youngrodder
youngrodder's Avatar
Nice work....Thanks for sharing the process. It's cool to see how you improved the set up.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-21-2017, 10:35 PM   #15
mongocanfly
mongocanfly's Avatar
your doing nice work...WOW...that was a mess..just when you think you've seen it all...a tractor 3rd link for a panhardbar?...wow
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-20-2017, 03:15 PM   #16
Advanced Design
Advanced Design's Avatar
Awesome work, love your welds!
Advanced Design is offline   Reply With Quote
Old 11-20-2017, 08:31 PM   #17
oldman3
oldman3's Avatar
Beautiful work...Jim
oldman3 is offline   Reply With Quote
Old 11-28-2017, 02:12 PM   #18
dec010974
dec010974's Avatar
I would like to more pics when its done. I'm trying to decide which way i want to go with my new ride.
dec010974 is offline   Reply With Quote
Old 11-28-2017, 02:47 PM   #19
tinydb84
tinydb84's Avatar
Those are all the pics I got. He took it home last weekend. You can follow his instagram thought @yosoyjames
David
Instagram: myfabguy
Old 12-04-2017, 09:33 PM   #20
1957 Chief
Like everyone else said, great work!
Bubba
1957 Chief is offline   Reply With Quote
