11-21-2017, 10:38 PM | #1 |
Carpe manana
Do you have OEM CA emissions / smog equipment still in place?
Just curious who has CA emissions equipment still on their motor. I'm trying to reconstruct the missing system on my current Blazer build. My other blazer has its original equipment still intact.
Let's see some photos documenting the CA emissions systems.
11-21-2017, 10:44 PM | #2 |
Who Changed This?
Re: Do you have OEM CA emissions / smog equipment still in place?
My truck has the Federal emissions package, so I can't take pictures to help you. However, if you need to see what was used, the Chassis Service Manual has pictures and schematic diagrams of the systems used, to help you. Someone here was gracious enough to scan in the entire manuals for a number of years; you should be able to find what you may need from those manuals.
11-21-2017, 10:49 PM | #3 | |
Carpe manana
11-21-2017, 11:34 PM | #4 |
I can take more if you need them. I guess I should have called and let you look at it early that morning when I came back through Albuquerque.
11-21-2017, 11:36 PM | #5 |
BTW, mine has what sounds like an exhaust leak. I had new exhaust installed, but the noise is still there. Do you have any ideas.
11-22-2017, 12:07 PM | #6 | |
It looks like the vacuum line from the (california/emissions) carb has been plugged (in your 1st pic) and I believe this normally runs to the emissions unit. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
11-21-2017, 10:45 PM | #7 |
Carpe manana
Slowly coming together on the blue blazer.
11-22-2017, 11:26 PM | #8 |
Carpe manana
I've read the pump can seize over time and makes a racket but wouldn't suspect that would sound like an exhaust leak. If the diverter valve diaphragm fails it can produce a vacuum leak (read it can be cured by placing a BB in the signal hose to the valve) and continuously dump air into the exhaust manifolds that can cause back firing.
I found a guy who rebuilds divertor valves for the corvette crowd. Rock auto recently had a close out on some USA made reproduction diverter valves for like $10. These are plastic and the hose tubes oriented differently but I may use one until I can have the original unit rebuilt. Next time Larry! Thanks for the pics!
11-22-2017, 11:28 PM | #9 |
Carpe manana
Here's an AIR schematic for a small block - generic and not specific for a pickup though.
11-22-2017, 11:32 PM | #10 |
Carpe manana
I've been able to scrounge some NOS pieces to rebuild the system in my Blazer.
11-22-2017, 11:33 PM | #11 |
Carpe manana
....even a pump.
11-22-2017, 11:36 PM | #12 |
Carpe manana
The emissions decal for CA emissions half tons in 72 made use of this LM decal (not reproduced to my knowledge).
11-24-2017, 11:03 AM | #13 |
Carpe manana
Example pic of AIR brackets and AC brackets for SBC 1972
11-26-2017, 03:55 PM | #14 |
I have a complete AIR System on my 68 if you need any more info/pictures. As I recall, at least in 68 only the standard transmission - half tons had AIR systems. There were probably different rules in later years.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
11-26-2017, 05:35 PM | #15 |
Guess I am lucky. My 3/4 ton 1970 had no emission controls, outside of the spark and fuel calibrations. Good luck getting it all together, so many people removed all that stuff years ago.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-29-2017, 01:17 AM | #16 | |
Carpe manana
No 3/4t trucks had AIR - I believe these were emissions exempt.
11-30-2017, 03:25 PM | #17 |
Here's the tag from my '72 California 3/4 ton 4x4 Suburban. I have no reason to suspect the fender well has been replaced. The engine has been replaced along with the exhaust. PO installed headers/aluminum intake. No AIR brackets left.
11-30-2017, 11:08 PM | #18 |
Moderator
A suburban is not considered a commercial vehicle like a truck is here. It would make sense that it would have AIR vs. a truck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-30-2017, 08:15 PM | #19 |
I bought a ‘70 C-20 in January of 1970. It was a 307cu in and 3 speed manual trans. Not sure where it was built but I bought in Wheaton Illinois. It had the air pump on it. Was pretty common in those days to just take the belt off the pump. I accidentally hooked a radiator hose to the pump during a valve job... left a white smoke screen behind it like I was running moonshine. You don’t forget that experience.
11-30-2017, 08:33 PM | #20 | ||
Carpe manana
11-29-2017, 01:15 AM | #21 |
Carpe manana
I'm really curious about 68 actually because I've seen two half ton 4wd trucks both seemed to have AIR brackets but CA emissions not listed on the SPID. Did all standard tranny V8 trucks in 68 have AIR equipment?
11-29-2017, 01:14 PM | #22 | |
He traded it in on a new 69, 350 engine, 350 automatic, and it did not have an emissions system.
11-29-2017, 10:01 PM | #23 | |
3/4 ton trucks and heavier seem to have had fewer smog control requirements in 68.
11-29-2017, 09:23 AM | #24 |
All about them K’s
Looking good Pete!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-30-2017, 06:39 PM | #25 |
Carpe manana
Thanks! Shoot me a text when possible - lost all my phone data
