anybody ever been successful w/ repro windshield trim?
so has anyone ever successfully installed repro front windshield stainless/chrome/whatever trim/molding? asking for a friend...
![]() Join Date: Dec 2016
Re: anybody ever been successful w/ repro windshield trim?
I have used trim from the rubber mfg. company in Ohio. Im drawing a blank on their name, but it worked well with their windshield gaskets.
Green and white boxes, can't for the life of me remember the name. |
Moderator
![]() Join Date: May 2007
No...although many have tried it seems to be an exercise in futility. Best bet is oem deep trim (67-70 style) with a Precision brand gasket.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Sep 2010
I agree 100% with this... That is what I am running on Papa J
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
That's it, precision....this getting old stuff, nymph.
It's not perfect, but I have had luck with precision trim. But Ledzep is correct, non better than OEM. |
#7 | |
![]() Join Date: Feb 2001
That's what I did even though I have a 70 ... I was told I think by WES that this was the best approach. ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
so, if I get Precision stainless and Precision gaskets, I may have a chance? Because I'm assuming finding OEM trim is gonna be difficult
#9 | |
![]() ![]() Join Date: Jan 2011
I am using Trim Parts 67-70 trim with a Precision 67-70 gasket. The trick to this install is KY jelly believe it or not. There are three 'groves' in the gasket. One is for the pinch weld, obviously where the gasket wraps over the lip and actually holds it in the truck. The second grove is for the windshield glass itself. What I do is use KY jelly in the grove for the windshield. As I am putting it on the windshield I pinch the gasket open and use a Qtip to spread the KY in that grove. It's going to be slippery but you want the windshield to be able to kinda move around in the gasket as you rope in the windshield. I also put a generous amount of KY around the lip / pinch weld of the truck. (maybe not so much around the bottom edge of the pinch weld.. more on this in a sec) NOT the gasket itself, it will be a major pita to get your chrome in the grove. With the KY in place, go ahead and work the gasket on to your windshield. Use that blue painters tape to temporarily hold the gasket on while you work the chrome in. Take your time, pull the gasket back and make absolutely sure that chrome lip has seated into the gasket as best you can.. then check it again. I cant tell you enough how critical it is at this stage to make 110% sure that chrome is locked in. Start with the top piece, then the sides. It helps on the sides to start it about 4" away from the corner and kinda push it toward the top until it stops. You'll feel it stop. The key here, no KY in the trim grove. Only in the grove for the windshield, and around the pinch weld. KY ( to me ) is a bit safer to use than oils, sprays, dishwashing liquid etc. it's water based and will dry. Of course you can kinda wipe it down as you go. Once the chrome is in, and you have your rope in the gasket You want your rope to be as deep into that gasket (pinch weld grove) as you can get it. Overlap the rope on the top part of the windshield. Have a buddy / wife help you sit it into the truck. Hook your top corners in first. The windshield and cab pillars are wider as they go down so kinda start about half way down and hook in the top corners of the gasket as you go up, the same on both sides. Push it up pretty good, you want that as far up as you can get it. If you put KY on the bottom edge of the pinch weld -- you'll need someone to hold your windshield in at this point. If no KY, it will sit there on it's own, but the roping in part will be more difficult. Start in the center of the top edge, and just start working the gasket over the lip. Go slowly and make sure you get the gasket completely over the lip. The Precision gaskets have a 'secondary' lip that has to come over the pinch weld to allow the windshield to fully seat into place. Work toward each upper corner.. as you make that turn, it really helps to have someone put a little pressure on the glass as you go. Open hand.. not too hard. Good luck man.. it aint easy. The biggest thing is just take your time. Making sure that chrome is in the grove and locked in my opinion is the hardest part. But, 67-70 trim is much, much easier to work with.
I have nice original trim on a 72 cab in my pasture but you would need to come remove it .
Actually I am running the OEM Trim that I had the dings removed and polished in a precision Gasket...
ok...just so I dont get any deeper into this.....will a 67-70 gasket and nos trim fit on a '72 windshield?
Subscribed
I bought windshield trim from brother. No way in $@LL that windshield was going in with the trim on. Bums me out Back glass was a breeze Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
Moderator
You need to make sure the gasket and trim are both 67-70 style. The windshields are all the same size 67-72, so gasket to windshield is no issue.
#15 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
The thing is, there is a short trim and a long or deep trim. There is also the corresponding deep and shallow trim gaskets. Neither will work in the wrong gasket, they must be mated to the correct gasket. You install the gasket to the glass and then the trim to the gasket. Use masking tape every 10" inches or so to hold it all together once you have installed the 1/4" nylon pulling rope. Get the tools, especially the hook tool it will make the job much easier and don't be afraid to squirt some windex around the perimeter to help the gasket slip in... https://www.youtube.com/watch?v=SOU_0HpS7To
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#16 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
#17 |
I've never met anyone yet who has had any success with reproduction trim, no matter who they bought it from, or which gasket they tried to use.
My son bought a set of repro trim from LMC, and just ended up throwing it away and using a plain gasket after a highly experienced glass installer finally gave up trying to get it to work. I have a set of 1971 OEM trim that only has a couple of minor dings in it that I have been saving if and when I ever decide to use it.
"Negative people always seem to have a problem for every solution" |
#18 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Here's my experience: http://67-72chevytrucks.com/vboard/s...d.php?t=484773
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#19 | |
Tech Help
![]() Join Date: Apr 2012
As others have stated, OE trim is going to be you best bet. After market trim only has be slightly off in the bends for it not to fit right, and worse still, pop out. Please watch our video as it shows the techniques needed to get this seal seated correctly. Seating the top first is going to render the best results...regardless of what the GM manual says. -Derek https://youtu.be/SOU_0HpS7To
PRECISION Updates Subscribe --->Installation Videos Follow ------->Instagram Like---------->Facebook |
#20 |
So I have a question about original windshield and back glass trim . How do I keep from destroying good trim off my 72 parts truck cab ?
