Old 12-06-2017, 05:02 AM   #1
jams97355
Flat out engineering C-4 axle problem
The bracket that mounts the dog bones to the hub assembly cut into my aluminum axle. Went in about 1/2". Everything is tight and mounted properly. Only did it on the drivers side. Got a new axle and replaced all the bushings with polyurethane. There is only 1/4 inch between the bracket and the axle. Could the torque from my big block twist the axle mounts enough to do this or is there some other cause?
1957 Chevy 3100
402 BBC
700R4 transmission
c-4 Flat Out Engineering suspension
jams97355 is offline   Reply With Quote
Old 12-06-2017, 09:08 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Flat out engineering C-4 axle problem
got any pics of your setup?...did you talk to Don at flatout?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-06-2017, 01:04 PM   #3
jams97355
I haven't talked to Don yet. Was just in the process of checking everything over again before I called to make sure I didn't miss something. Also it just got real cold in the shop as we got our first freeze last night. I'll give him a call and see what he thinks is going on.
1957 Chevy 3100
402 BBC
700R4 transmission
