Old 12-07-2017, 02:55 AM   #1
Picard
1969 Chevy C10 LS Build - South Africa edition
Hi Everyone.
Quick intro.
I'm from Johannesburg South Africa and love old American cars. I've owned a 1981 Trans Am for many years. 4 years ago I decided to strip it down, paint and update it. After a lot of work, we finally managed to get it back on the road this year. It was a really tough build but with the help of my brother and a few mates, we got it right.
It’s currently running a LS1 with a 4l60e.
Now that the Trans Am’s finished, my brother and I had a few options on what to build next. We opted to take on a 1969 Chevy C10 SWB. It is right hand drive and South African built, so as far as I understand it the load bin is slightly different.
Picard is offline   Reply With Quote
Old 12-07-2017, 02:56 AM   #2
Picard
Re: 1969 Chevy C10 LS Build - South Africa edition
We’ve been reading through this forum and see there’s a wealth of knowledge to be learnt from here. Looking forward to interacting with everyone.
Unfortunately for us, the Rand/Dollar exchange is quite hectic so we will need to try and manufacture or source as much as possible locally. As much as we would love to pick up a catalogue and click buy, the pocket won’t allow for it. 
We’ve seen so many beautiful trucks posted all over the internet, and the idea is to build a updated truck with slightly more modern suspension bits, upgraded brakes, aircon and power steering. Looks wise, we’ll still settle on colours etc later on, but if we could land up with something like this, we’d be happy.
These are the wheels we would prefer for it, but after a few pricing exercises they may land up on a wish list only.
A set of these Salt Flat wheels are on the wish list, however we may need to settle on a different wheel as by the time these land at our door we’re looking at about $4500 which is pretty steep.
We purchased the truck with a Chevy LM7 motor, which is a 5.3l cast iron V8. It also came with a 4L80 gearbox.
Having gone through a “LS” build before, we opted to rather purchase a running vehicle and managed to source this 2006 Chevy Lumina SS.
The Chevy Lumina here in South Africa is a Australian sourced Holden Commodore which has a 5.7l LS motor in it with a 4l60e box. Later models came out with the 6.0l LS2.
The car took a hard knock on its side. However it still drives, is completely stock with 120k km’s on the clock with a full service history.
This way, we will be able to use the motor, gearbox and have access to the computer box, which the LM7 doesn’t have. We may also still be able to salvage the callipers and some other odds and ends.
Old 12-07-2017, 02:56 AM   #3
Picard
And so, the Tear Down began.
We removed the load bin.
Disassembled the front end.
Before removing the Cab, we mocked up the LM7 so that we could start building up the engine mounts and gearbox mount. There are kits available in the States which would have made it quick and easy, but to keep costs down we decided to manufacture them ourselves.
We mocked it all up.
Notice the beautiful gearbox mount 
We marked out parts of the frame that would need to be trimmed to fit the LS motor. The frame will be reinforced, especially where any cuts are made.
Slowly the engine mounts started coming together.
And eventually landed up with this.
Old 12-07-2017, 02:57 AM   #4
Picard
Years of dirt and farm roads were caked into the chassis so I landed up taking a high pressure hose to it.
The original gearbox mount was a hack job and because we will be lowering the truck we decided to make up a new gearbox mount.
This was the original cross member/mount
After a bit of cutting, grinding and welding we made this up.
In this picture with both mounts in, you can kind of see the difference in height that the new gearbox mount has bought us.
The frame also needs to be notched further back, so we did some more measurements….more cutting and grinding and fitted the C Notch. This we imported and purchased from CPP. Very well put together.
And like that, the frame drops nice and low.
Old 12-07-2017, 02:58 AM   #5
Picard
The ‘69 C10 has drums front and back. This obviously won’t work, so new drop spindles will be arriving shortly for it, and we’ve got discs and callipers from a later model C10 for the truck.
With having the Lumina available, we will be investigating perhaps using it’s callipers and discs for the C10.
The C10 is also a 6 Stud 127 pcd, and we’ve decided to change this out for a 5 stud setup which just helps us later on with wheel choices.
We purchased a 5 stud diff with a more suitable diff ratio for cruising. This will obviously need to be refurbished, and we may opt to go with a limited slip unit.
The rest of the suspension was removed.
Here you can see some more creative fixes on the control arms.
The chassis and suspension components have been sent off for sandblasting so that we can assess everything once it’s back and also work with clean parts.
Thanks for watching :-)
Old 12-07-2017, 08:26 AM   #6
35boulder
35boulder's Avatar
Welcome...I will be watching along on your build. Thanks for all the pics. Good luck with the build.
35boulder is offline   Reply With Quote
Old 12-07-2017, 08:35 AM   #7
Smitty
Smitty's Avatar
Welcome, looks great so keep up with progress reports.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 12-07-2017, 08:33 AM   #8
Perpendicular
Way cool!
Perpendicular is offline   Reply With Quote
Old 12-07-2017, 08:55 AM   #9
yuccales
yuccales's Avatar
Welcome! Love all the pics. That's going to be a great build! That Riviera is way cool, as is the TA.
yuccales is offline   Reply With Quote
Old 12-07-2017, 09:23 AM   #10
hewittca
hewittca's Avatar
Nice work so far! I like your approach of ingenuity versus just buying a bunch of bolt ons (although wouldn't we all love that luxury at some point?). I'm curious to see what these differences in the "load bin" are compared to a US C10. Also, I know I'm not allowed to say this here, but that F100 looks pretty cool too.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 12-07-2017, 09:28 AM   #11
too much stuff
Roadtrip!
too much stuff's Avatar
Welcome aboard. Keep us updated on this build. Nice work.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-07-2017, 04:00 PM   #12
Picard
Thanks for the warm welcome!
Will be updating the post as we go along. Will post up some pics of the other toys we're fortunate to play with.
Old 12-07-2017, 04:45 PM   #13
harpo231
harpo231's Avatar
Nice ! I want righthand drive, people be trippin to see that over here !
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-07-2017, 06:54 PM   #14
'70_402
'70_402's Avatar
This is the first right hand drive trucks like this I've ever seen.
'70_402 is offline   Reply With Quote
Old 12-07-2017, 08:21 PM   #15
72 tigger
72 tigger's Avatar
Looks like a nice project- following along. How beat up is the load bin?
72 tigger is offline   Reply With Quote
Old 12-07-2017, 08:59 PM   #16
flashed
Welcome ,Im in to see the rest .
flashed is offline   Reply With Quote
Old 12-07-2017, 09:12 PM   #17
toms68cst
toms68cst's Avatar
Welcome! I also think that's the first real right hand drive 67-72 I've seen on this site. Looks kinda strange.
Good luck with your project. You are off to a fine start.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 12-08-2017, 12:45 AM   #18
RenoKeene
Florida Edition
RenoKeene's Avatar
Welcome aboard from Florida, USA!
You guys do good work. Right hand drives are extremely rare over here.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
