Old 12-16-2017, 02:46 PM   #1
sixty4bigwindow
sixty4bigwindow's Avatar
T Bird/Taurus Electric fan wiring
Hey fellas, anybody ran the 94 to 97 T Bird, Taurus electric fan in their rig? Just got mine feom Summit last night, and stupid me didnt see where it said nothing was included lol.. ive tracked down the 3 wire connector. But now its a matter of what else I need to hook it all up and make it work. I know some relays and probably a manual switch are in order, bit I'm trying to be as frugal as possible lol! Under $30 would be spectacular.
sixty4bigwindow is offline   Reply With Quote
Old 12-16-2017, 08:14 PM   #2
LVPhotos
LVPhotos's Avatar
Re: T Bird/Taurus Electric fan wiring
Why that fan? Cost? I run a 3300cfm fan from Flex-a-lite Black magic https://www.amazon.com/Flex-lite-180.../dp/B000CNHFNA Fan control from Speedway Motors. https://www.speedwaymotors.com/Speed...uges,2356.html
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-16-2017, 08:23 PM   #3
sixty4bigwindow
Exactly right LV, cost lol. This one was 79 shipped.. But I mean if the flex a lite is a simple plug and play, and I'm gonna need 100 in parts to make this one work, I will save and do the flex a lite lol.. what did you have to do to make yours work in the rig??
Old 12-16-2017, 08:29 PM   #4
LVPhotos
LVPhotos's Avatar
I had left over aluminum i made brackets from... 1x1 and flat but comes with own. You see fit on 62 og radiator. Price is what I posted. The speedway controler vs the flex-a-lite is better and hooks to water temp sender and not a probe through radiator. So if temp says 180 on gauge you set fan on off to it.
Old 12-16-2017, 08:33 PM   #5
LVPhotos
LVPhotos's Avatar
Those are original tabs for schroud.
Old 12-16-2017, 10:58 PM   #6
Captainfab
60-66 Nut
You might PM a moderator and see about having this thread moved to the electrical section. You will be more likely to find someone there with an answer to your question.
Old 12-16-2017, 11:23 PM   #7
LVPhotos
LVPhotos's Avatar
Com on man... I layed it out more than once. 2 wire, 3300cfm. Flex-a-lite BLACL MAGIC. Ran same fan on 1998 Dodge Durango Pre runner here in 120+ degrees but you all want a used pos ford junk yard special?
Old 12-16-2017, 08:30 PM   #8
LVPhotos
LVPhotos's Avatar
Get fan without controler, lower price and buy other controler. Or use on/ off toggle. Two wire fan.
Old 12-17-2017, 10:07 AM   #9
verdell
verdell's Avatar
[QUOTE=sixty4bigwindow;8106563]Hey fellas, anybody ran the 94 to 97 T Bird, Taurus electric fan in their rig? Just got mine feom Summit last night, and stupid me didnt see where it said nothing was included lol.. ive tracked down the 3 wire connector. But now its a matter of what else I need to hook it all up and make it work. I know some relays and probably a manual switch are in order, bit I'm trying to be as frugal as possible lol! Under $30 would be spectacular.[/QUOTE
I used a fan from a Cougar XR7 with a 100 plus amp alternator and 80 amp relay. Been running this set up for 4 years with zero issues. Hope this helps.
http://forums.corral.net/forums/gene...topics/1112478
verdell is offline   Reply With Quote
Old 12-17-2017, 11:40 PM   #10
Cooper197
Cooper197's Avatar
No need to spend all that money on the flexalite. The Lincoln Mark VIII Fan, which should be the same as the T Bird fan, is plenty for these old trucks. They are very reliable and move a ton of air. I've had my truck in 115 degree heat, in stop and go traffic with the A/C on and not had the heat gauge rise above about half. It's a big 18" fan, I got mine for around $70. A decent 2 speed fan controller, or dual fan controller and you'll be set. If you spend much more than $150 or so, I'd be surprised.
My set up is a Mark VIII fan with a Dakota Digital fan controller and relays. You can set the exact temp you want it to turn on and off the high and low speeds and customize a few other settings as well. A couple years in and it's doing great so far.
Sure you can spend $285 on just the fan...but why? It's rated for 3,300 CFM whereas the Mark VIII fan is shown between 4,000-5,000.
Cooper197 is offline   Reply With Quote
Old 12-18-2017, 10:16 AM   #11
grubsster
grubsster's Avatar
This is what I used... they have a 200 degree switch as well. I do keep an extra kit in the glove box in case something fails. Has not failed in over a year. I have had no problems with the Taurus fan. Works great in high temps and easy to get an affordable replacement if necessary.
Partssquare Cooling Fan Thermostat Kit Temp Sensor Temperature Switch 40 amp RELAY KIT https://www.amazon.com/dp/B015R9AVMA..._JH8nAb02H5A5C
grubsster is offline   Reply With Quote
Old 12-18-2017, 05:02 PM   #12
sixty4bigwindow
Grub did your fan come with the wires and conncector? Or did you buy it seperately? This one doesnt have it, Id have to buy the 3 connector too.
Old 12-18-2017, 07:27 PM   #13
grubsster
grubsster's Avatar
If you are talking about the three connector to the fan I picked one up at the pick and pull. Make sure you use heavy gauge wire. I used 10 gauge because that fan draws some amps when it first kicks on. You will also want to upgrade your alternator to at least a 12si. I installed a 100 amp out of a 97 Buick. Here is the wiring diagram that came with the kit. Also that is a 2 speed fan, I just wired to the high speed side.
Old 12-18-2017, 10:03 PM   #14
rvrfoot
This ia what i am going to use on mine.Name:  DSCN1022.jpg
rvrfoot is offline   Reply With Quote
Old 12-25-2017, 10:44 PM   #15
racecougar
racecougar's Avatar
'94-97 4.6L MN12 (Tbird/Cougar) fan here...controlled via the PCM through two of these relays:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-26-2017, 01:19 PM   #16
UTSA
UTSA's Avatar
I used the Taurus Electric fan, BMW dual temp sensor and relays from a volvo 850 wagon to control all of it. There was also an auto reset breaker for the hot wire coming from the battery to the relays. Let me know if you need more details.
1965 C10 350 combo
UTSA is offline   Reply With Quote
Old 12-27-2017, 11:28 AM   #17
racecougar
racecougar's Avatar
...not to mention that it moves more air than the "BLACL MAGIC". Lol.
