12-18-2017, 05:42 PM | #1 |
a very specific question about screws/bolts
does anyone know the size or where I can find the size of the screws/bolts that hold the washer fluid jug bracket on a '72?
12-18-2017, 07:07 PM | #2 | |
Re: a very specific question about screws/bolts
If that does not work pull a bolt from around the area under the hood that looks to be the same in size, fit it to the missing area, then take it to the hardware store for a duplicate or shorter/longer appropriate size. I would bet its a 7/16 or 1/2 inch with 16 to 20 threads per inch. |
12-19-2017, 11:45 AM | #3 |
Just looking at the pictures of mine, they look like 5/16-12 hex washer head screws. I would have to go pull one to be sure, though.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
12-19-2017, 01:06 PM | #4 |
3/8 FLANGE TAP SCREWS 1/4 x 1/2 - Heads are recessed. Same as the ground strap/rear marker ground screws, only coated.
1/4 x 5/8 works.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
