Old 12-19-2017, 12:38 AM   #1
UKNOWME
UKNOWME's Avatar
Newb questions
Although I will be new to the 60-66 world I am not at all new to this forum. I’m am 99% certain I’m have acquired a 1961 c30 dually. I’m having a hard time finding the info I’m looking for...
Does anyone manufacture replacement dually fenders?
Does anyone manufacture lowering kits?
I have searched and don’t seem to find anything.
I’m excited to begin working on this truck! Thanks for any advice and direction!
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 12-19-2017, 12:39 AM   #2
UKNOWME
UKNOWME's Avatar
Re: Newb questions
I would like to bag it but not sure how feasible that will be.
1964 Chevy c10
Old 12-19-2017, 07:34 AM   #3
PGSigns
PGSigns's Avatar
Re: Newb questions
Post some pictures so we can see what you are working with.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-19-2017, 11:25 PM   #4
andyh1956
Re: Newb questions
Yeah a C30 should be a Cab & Chassis with a work body of some type on it. That I know of they didn't build Dually trucks for about 15 more years.
andyh1956 is offline   Reply With Quote
Old 12-20-2017, 12:19 AM   #5
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Cab and chassis with a dual rear wheel? Or are you saying CHEVROLET didn’t use dual rear wheels at all until around 75?
1964 Chevy c10
Old 12-20-2017, 12:34 AM   #6
Captainfab
60-66 Nut
Re: Newb questions
The factory dually bed with the fender extensions did not happen until '73. Prior to that a C30 was either a cab and chassis with duals on the rear or single rear wheels with a stepside or fleetside bed
Old 12-20-2017, 12:38 AM   #7
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Ok that makes sense. So it was for sure a cab and chassis. Do you know if the cab and chassis has the same wheelbase as a longbed?
1964 Chevy c10
Old 12-19-2017, 11:52 PM   #8
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Be warned, it’s rough!
1964 Chevy c10
Old 12-20-2017, 12:04 AM   #9
Lil Loafer
Re: Newb questions
What are your plans, other than lowering it?
Lil Loafer is offline   Reply With Quote
Old 12-20-2017, 12:17 AM   #10
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Not sure yet. So many ideas....
The engine doesn’t run right now. No idea about the trans.
1 idea was to leave it ratted out but lower or bag it on 20” 8 lugs or even 22” semis. Get the 6 cylinder running. Reupholster the seat. Make a stake flat bed.
Option 2 includes a dually bed and maybe some bodywork.
Option 3 is to do any LS swap
Option 4 is make it a shortbed possibly try to convert to 1/2 suspension.
It really is endless
1964 Chevy c10
Old 01-07-2018, 06:32 PM   #11
UKNOWME
UKNOWME's Avatar
Re: Newb questions
I’m looking at doing a 73-87 front crossmember swap to gain the newer suspension, disc brakes and power steering. Anyone see any issues with that?
1964 Chevy c10
Old 01-07-2018, 11:58 PM   #12
Captainfab
60-66 Nut
Re: Newb questions
No, nothing wrong with that. That is what I started doing back in the early '80's. Now days most people want dropped spindles and springs and don't want to change the crossmember. There are more options now than back when I started doing the swap, but those options do cost more money.
Old 01-08-2018, 12:23 AM   #13
UKNOWME
UKNOWME's Avatar
Re: Newb questions
I’m ok with that too but where do I get spindles and springs? This c30 has torsion bars also.
1964 Chevy c10
Old 01-08-2018, 12:39 AM   #14
Captainfab
60-66 Nut
Re: Newb questions
Sorry I didn't go back and look at what you are working on. A crossmember swap would be the best IMO. I don't think you can put the '60-'62 dropped spindles on a '61 C30. I was mainly talking about other people in general that want dropped spindles and springs for their trucks..
Old 01-16-2018, 03:56 PM   #15
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Anyone know if the 61 apache 30 frame is the same specs on the rear as a 1963-66 c30? I was looking at some 4 link setups and they start at 1963.
1964 Chevy c10
Old 01-17-2018, 12:59 AM   #16
Captainfab
60-66 Nut
Re: Newb questions
Since your truck is a C30 with leaf springs, and in looking at the pics, I would say that the frame should be about 34" wide from a little behind the back of the cab rearward. So yes the frame should be basically the same width as a '63-'72 frame. Bit at the same time yours will have a different profile since it is designed for leaf springs. So any rear suspension 'kit' for a '63-'73 will not be an exact bolt in. I'm not sure if a kit for a '73-'87 would be a better fit or not. Some measuring would be necessary.
Old 01-17-2018, 01:47 AM   #17
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Thanks for the suggestions Captainfab! I may try an inexpensive option first and use a flip kit for a 73-87 c30 first.
And actually that 4 link I was looking at will fit all the way to the end of the squarebody so it would probably be the same.
1964 Chevy c10
Old 01-16-2018, 08:22 PM   #18
duallydude63
Re: Newb questions
if U want to do a stepside U will have to have the fenders extended out( on mine i had them extended out four inches) am doing a 63 dually if U google 6o/66 dually there a guy that did a blue one some yrs ago!!
duallydude63 is offline   Reply With Quote
Old 01-16-2018, 08:46 PM   #19
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Here’s kinda what I’m looking at if I do a fleetside.
1964 Chevy c10
Old 01-16-2018, 08:48 PM   #20
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Kinda put the cart ahead of the horse considering I still have to file for a lost title and have it towed from my friends house but I picked up a pair of these yesterday.
1964 Chevy c10
Old 01-16-2018, 08:52 PM   #21
joe dirt
joe dirt's Avatar
Re: Newb questions
nice score, that grill looks to be in near perfect shape...the 61 insert is hard to come by in good shape...hood looks good too
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 01-16-2018, 10:40 PM   #22
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Thanks! Hood is my least favorite part of the truck.
Originally Posted by Clyde65 View Post
Before I spend a dime, get the title worked out. Then go for it!
Yeah I need to work on that this week.
1964 Chevy c10
Old 01-17-2018, 03:59 AM   #23
joe dirt
joe dirt's Avatar
Re: Newb questions
Well you can turn that hood to help fund the project...they are pretty saugt after....post it up in the for sale section
1964 c10 swb
Old 01-18-2018, 12:46 AM   #24
UKNOWME
UKNOWME's Avatar
Re: Newb questions
Thanks for the suggestion .
1964 Chevy c10
Old 01-16-2018, 08:54 PM   #25
Clyde65
Clyde65's Avatar
Re: Newb questions
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
