Old 12-24-2017, 09:48 AM   #1
my240
Question blower resistor problem
I have a 1979 chevy k10, shortbed, 4x4, with 400 sbc and it's been a great truck for 40 years. All original with 51,00 miles on it. Decided to put in a new blower resistor. Truck heater fan always ran on low when you turned on the key, however with this new resistor when you turn key on the fan is running in high. Is it the wrong resistor? it looked correct. Can I run the truck by just disconnecting this at the blower?
my240 is offline   Reply With Quote
Old 12-24-2017, 11:44 AM   #2
Man With A Gun
Man With A Gun's Avatar
Re: blower resistor problem
Is it possible you reinstalled the connector upside down?
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 12-24-2017, 12:39 PM   #3
my240
Only one way to connect the plug to the 3 prongs. Is there a difference when you put it in the blower? will go in either way.
Old 12-24-2017, 02:09 PM   #4
Man With A Gun
I don't know, it just sounded to me like your high fan speed wire is connected to the Lo speed terminal which is on all the time.
If you have a 73 or 74 make sure you don't have the cold selector slider all the way to the left or it will be in max mode which I think makes the fan run high all the time.
I used to have a 74 back in the early eighties and that's the way I remember it worked but I am not 100 percent positive.
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Old 12-24-2017, 07:21 PM   #5
wilkin250r
wilkin250r's Avatar
I'm not sure about your current problem of running on high.
But your fan running on low all the time is actually intentional, to circulate air in the cab. It was designed that way.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
