12-24-2017, 04:15 PM | #1 |
made in america
cpp brake issue
so i did the swap to disc brakes on my 64. wanted to go a little lower and stop a little bit better. so i made the call to the cpp guys. they set me up with all the stuff to get it done. im finished now and for some reason my front brakes drag like crazy. ive bled all around there is definitely no air in the system. the master cylinder was bench bled. i dont know what to check next. can yall help?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree 2004 corvette- lowered, borla, tuned. slow my old girl 1966 c10- 305v8, t-5 sold |
12-24-2017, 04:17 PM | #2 |
Re: cpp brake issue
Proprtioning valve? Drum disk master? Are the fronts hooked to the proper outlet?
12-24-2017, 04:19 PM | #3 |
made in america
Re: cpp brake issue
its a non power disc drum master. everything seems to be properly hooked up. ill post a picture in a second
12-24-2017, 04:24 PM | #4 |
made in america
Re: cpp brake issue
12-24-2017, 05:15 PM | #5 |
Re: cpp brake issue
CPP proportioning valve is a known POS, just wait a few weeks and it will start leaking too.
12-24-2017, 10:02 PM | #6 |
Re: cpp brake issue
Based upon your description, I would also have to suspect the proportioning valve. I to had a CPP system it lasted about three months before the valve failed.
12-25-2017, 12:08 PM | #7 |
Re: cpp brake issue
12-25-2017, 01:39 PM | #8 |
Re: cpp brake issue
I must have got the good one. No problems here 6 months in.
