bagged rear coils in a 63
,, My stock rear coils seem to be tired, I have though about going the bagged route,, thoughts or suggestions?
![]() Join Date: Aug 2004
Re: bagged rear coils in a 63
I have bags, cups and dual schrader valves. Let’s me lower it when I want and also add air when I am towing my camper.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Thanks just ran through the camper build thread , whose bags did you use?
I used Firestone 2500 bags, twin schrader valves to license plate holder.
I got mine from Air Ride now Ride Tech but Firestone 2500 bags and some cups can be had for less with some shopping. Funny thing is the 2600s on front are the same as rear on my helpers on 1ton
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
very cool !
I did the same simple separate lines to Schrader valves on my rear bag swap. They are Slam Specialties SS7 bags.
The coils that came out were OG, sagged out and torch lowered so naturally the ride was massively improved.
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
What is the reasoning of the twin Schrader valves?
One for each side. Indavidual bag adjustment.
I got 4... 4 bags 4 valves
![]() Join Date: Feb 2013
Oh ok I was just thinking you had bags in the rear but I think I got it down now. And thanks man for tagging that post I had actually made it but I was having a hard time finding it. I was looking in the wrong place haha appreciate it.
It's Better With Nitro
I also run Firestone double fluted air springs in the rear of my 63 C10.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
![]() Join Date: Aug 2017
Good simple info here that I had also been wondering about.
65 short step edited by staff |
#15 |
#16 |
I used Air Lift D2600 bags. They'll bolt in place of the spring by drilling two mounting holes up top, and making room for the air fitting to pass through the frame. The bottom mounts with a single bolt through the trailing arm just like stock.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#17 |
This is why I bagged my truck...
