Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-03-2018, 02:11 AM   #1
Short 3/4
WTB HO-52/72 4.10 gears
Just need good ring and pinion, but will buy whole center section. Also might be interested in rear brake parts. Thanks, Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 01-03-2018, 04:16 PM   #2
1960chevypanel
Re: WTB HO-52/72 4.10 gears
I can help with the brake parts. No pumpkins..
1960chevypanel is offline   Reply With Quote
Old 01-04-2018, 09:43 PM   #3
Short 3/4
Looking for parts for 12x2 with slid on drums for a K20, 64-? What do you have?
292-SM420-T221
Old 01-06-2018, 01:02 AM   #4
aotte1
Ok,
The 4:10 or 4:11 gears are not very common. They are more common in the later years the Easton rear was used, especially behind automatic transmissions.
You may want to also ask in 67-72 parts section. Most common on 69 to 72 trucks, but still kind of rare. You might even find a "No-Spin".
Hope this helps.
aotte1 is offline   Reply With Quote
Old 01-06-2018, 12:52 PM   #5
Short 3/4
Originally Posted by aotte1 View Post
Ok,
Hope this helps.
I did post there as well, thanks for the tip, Tom
292-SM420-T221
Old 03-08-2018, 04:06 PM   #6
Bucky10pt
I've got one I'll have to check what it is when I can dig outta snow
1967 GMC fleetside LS
1970 C10 Fleetside LS 5.3 4L60e
1971 C10 Utility LS 4.8 4L60e
1955 L3800 Panel Truck 7469 orig miles
Bucky10pt is offline   Reply With Quote
Old 03-09-2018, 10:48 PM   #7
CousinTone
Tom, I have a 64 C20 that I'm converting to 1/2 ton for ride purposes and I"ve got what I believe is an HO72 rear end. I turned it manually and it appears to have 4:10/4:11. I"ll go under and take some pictures of it. I'm in North Orange County and its not too far of a BEAUTIFUL drive down. I'll let you know and post pictures of what I've got tomorrow in the sunlight (rain if forecast but I'm thinking positive). If i have what you're looking for, I'll pass on a good price since someone else on the board set me up on the new rear end, What goes around comes around. Tony
CousinTone is offline   Reply With Quote
Old 03-10-2018, 03:26 AM   #8
Short 3/4
Thanks Tony,
Found a good one locally, so no longer looking. Hopefully you can find it a good home as I know others looking for that ratio.
Appreciate the offer,
Tom
292-SM420-T221
Old 09-08-2018, 06:20 PM   #9
racenhogs
I'm in need of a center section...please HO 52 with the 4.10
racenhogs is offline   Reply With Quote
Old 09-08-2018, 06:16 PM   #10
racenhogs
Do anyone have a center section that I can buy...I have a 54 3600 that needs a gear change and want to find an HO-52 with the 4.10 gear.
