Old 01-03-2018, 08:11 PM   #1
collin70k/20
collin70k/20's Avatar
70 k/20 14 bolt swap questions and concerns
Im sure this question was asked plenty of times. But i have a 1970 k20 chevy pickup with eaton ho52. Well today is decided to take a crap on me. so the 14 bolt dually rear i have is going in this weekend. (pretty sure it has 11.5 ringear). Any how i know you have to cut the spring perches and shock mounts. thats no problem. My one concern is will the back driveshaft on the eaton work on the 14 bolt? Any other questions, pointers, or advice is greatly appreciated thanks Collin.
1970 Chevy K20 pulling truck 406 small block
1967 Chevy K20 daily/street truck
My daily 1970 k20 - http://67-72chevytrucks.com/vboard/s...=1#post7568564
collin70k/20 is offline   Reply With Quote
Old 01-03-2018, 08:55 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 70 k/20 14 bolt swap questions and concerns
Just curious, what went south in the Eaton?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 01-03-2018, 08:59 PM   #3
collin70k/20
Axle broke.
Old 01-03-2018, 10:42 PM   #4
sweetk30
sweetk30's Avatar
i have heard eaton rears can swap the axles and spider gears with 14ff axles .
and 14ff were 10.5 ring gear . latter 11.5 were aam axles if i recall correctly from 00ish up trucks .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-03-2018, 11:02 PM   #5
BlueBullet
BlueBullet's Avatar
When I put in my 14 bolt in my 72 K20 I used the same drive shaft. My suggestion when you weld on the perchs have the axle on the truck, set the pinion angle, tac weld, then remove and weld up. I didn't have a big enough welder in my shop, so I went to our main shop and welded them on. I went off the angle of the original perchs, not a good idea. I think my angle ended up being off because the springs are different lengths on earlier models. Don't quote me on that but that is all I could come up with. Luckily I was able to shim it 6 degrees to get the proper angle. I could have avoided a $50 bill.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 01-04-2018, 01:18 PM   #6
jeffahart
jeffahart's Avatar
On my swap from HO52 to SRW corp14 I came up about 1/2" shorter yoke to yoke using zero rates on 1" setback. I made no drive shaft modifications. And definitely, dial in the perches for the pinion angle if you have to weld perches. But just for info sake, a one ton SRW corp14 will bolt directly into the K20 with only shock tab relocation. If you have a line on one of those with the right gears its a quick job.
j
White K20
jeffahart is offline   Reply With Quote
Old 01-04-2018, 10:28 PM   #7
Short 3/4
Good luck on your project. If you get a chance please check out my WTB ad, as you may be pulling off stuff I need
Thanks, Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 01-05-2018, 05:59 PM   #8
collin70k/20
ok thanks everyone for the advice. it is going to be this weekends project.
