Old 01-06-2018, 04:32 AM   #1
64c10step
Horsepower?
Have a BBC 468 with approximately 8.5:1-9:1 cr, edelbrock 11-413-8 cam .510lift intake and exhaust ,dur .006,intake tappet 264 exhaust tappet270, edelbrock rpm air gap intake, edelbrock 750cfm carb, msd e curve distributor, 049 high performance heads, speedway short tube headers with dual h piped exhaust. Block casting # 3999289. Has between 155-160 pressure in each cylinder cold. Wanted to see if anyone could estimate the horsepower, no access to a dyno, any estimates would be greatly appreciated! Thank you
64c10step is offline   Reply With Quote
Old 01-06-2018, 08:59 AM   #2
b454rat
Re: Horsepower?
With that small of a cam, I'd say 325-350 maybe. Last 454 I built was similar, but had more compression and cam, that was roughly 375-400....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-06-2018, 10:40 AM   #3
damnyankee36
damnyankee36's Avatar
Re: Horsepower?
I have a program called Dyno2000 that I've had for years that allows one to input all the specs of an engine to give you the hp and torque. Don't know how accurate it is but it's pretty cool to experiment with different parts to see the affect on output.
I suppose it's now called Dyno2018.
damnyankee36 is offline   Reply With Quote
Old 01-08-2018, 10:57 PM   #4
CST10
CST10's Avatar
Re: Horsepower?
I’ve got a 462CI with 049 heads ported, polished and matched to intake, edelbrock rpm intake, Holley 770 avenger carb, comp cam XM270 marine cam with .510 lift. Around 8.5:1 compression, roller rockers and lifters. 2400 stall converter.
Dyno’ed out at 379RWHP/419RWTQ all below 5200 RPMs. With a T350 tranny and driveline losses the shop estimated the engine at the flywheel was around 450HP/510TQ.
Very streetable.
I know it will roost a set of tires, ask my neighbors. Lol.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 01-09-2018, 01:26 AM   #5
64c10step
Re: Horsepower?
Thanks for the responses, greatly appreciated!
Old 12-25-2018, 11:42 PM   #6
64c10step
Re: Horsepower?
Anyone out there have experience with msd e curve distributor? Have a BBC 468 approximately 8:5 to 9:0 cr , 11-413-8 comp cam, rpm air gap intake, edelbrock 750cfm carb, shorty headers with h piped, 049 high performance heads. Wondering if any suggestions on which program to run for best performance if it's even possible to suggest.
Old 12-26-2018, 12:37 AM   #7
geezer#99
geezer#99's Avatar
Re: Horsepower?
Considering your elevation you’ll need lots of initial. Likely near 18. Plus 14 in mechanical all in by 3200 and another 10 from the vac advance.
Did you lower your floats slightly in the eddy 750?
How are you liking that air gap intake in the colder weather?
What transmission?
What rear gears?
