01-09-2018, 11:30 AM | #1 |
Factory under dash a/c ?
I found an under dash air self contained air conditioning unit installed in a 1972 Jimmy located in a wrecking yard. The fans works and I bought it for $50.00. I would like to install it into my 69 C10. It looks very well made and has a nice metal Jimmy name plate on it.
I'm wondering if this is a GM product that was offered by GM parts department to retrofit non-ac vehicles or an aftermarket unit. Does anyone have information on a unit like this? I'd like to change the Jimmy nameplate ( 1" X 6 1/2 " ) to an appropriate name plate for my 68 C10 and a couple of the outlet vents are damaged and need to be repaired or replaced. Can anyone help with that? I've attached a few pictures of the unit. |
01-09-2018, 01:01 PM | #2 |
Old member
Re: Factory under dash a/c ?
Check with these guy's they know their stuff.
They do refurbs on old equement to!1 https://www.classicautoair.com/?q=GM_OEM_Parts.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-09-2018, 01:24 PM | #3 |
I just sent an email to https://www.classicautoair.com/?q=GM_OEM_Parts.html Hopefully they can recognize my ac unit.
I didn't see anything on their website like my unit. |
01-09-2018, 03:51 PM | #4 |
Who Changed This?
Potentially dealer installed, or some A/C outfit local to them did it and then the dealer put that label on. That's not a "factory" A/C evaporator set up.
01-09-2018, 04:15 PM | #5 |
Moderator
Aftermarket unit, someone just stuck the Jimmy badge on there. Looks good though, someone wanted you to think it was factory
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-09-2018, 04:54 PM | #6 |
Old member
Here is another company that knows about under dash units.
http://www.oldairproducts.com/catalo...eaca4cdd0b53b3
