Old 01-09-2018, 03:32 PM   #1
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Any feedback on these headlights?
I want to try these on my 68 C10. Has anyone used this exact light for their truck?
https://www.summitracing.com/parts/h...eviews/?page=3
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 01-09-2018, 04:00 PM   #2
truckster
truckster's Avatar
Re: Any feedback on these headlights?
I haven't used them, but after reading the reviews I'm impressed. I was already planning on putting in headlight relays; I might just upgrade to these lights as well. I want to see better but keep the original look.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-09-2018, 04:06 PM   #3
HIGHWAY BY THE SEA
I am also impressed with the reviews. One of them is from an owner of a 68 C10 like mine. These look good, and I am tired of the dangerous low-light OEM ones. Low-light combined with drum brakes, and stupid pedestrians walking at night with ear buds, looking at their cell phones instead of where they are going all make for a BAD time.
Old 01-09-2018, 05:06 PM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Any feedback on these headlights?
Before any other upgrade of lights I suggest the relay kit first. It will amaze you at how well it will work with your regular lights. But adding the H-4 bulbs and housing is a great addition too!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-09-2018, 11:43 PM   #5
Pro299
Junior Member
You might also check into Cibie. Similar, but a little more expensive. I used Hella on my motorcycle and Cibie on the C10. I like the Cibie better. Either would be a big improvement over a sealed beam, but the Hellas don't seem to be as sharp, at least to my eyes.
Pro299 is offline   Reply With Quote
Old 01-09-2018, 11:56 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
The important thing is not to over drive your headlight's reach.
~Steven
Simi Valley, CA
Old 01-10-2018, 12:16 AM   #7
jjzepplin
jjzepplin's Avatar
Interested! I rarely drive my truck at night anymore. But this could save my life one day. And maybe someone else's.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-10-2018, 12:22 AM   #8
ho70
ho70's Avatar
Relay kit?
ho70 is offline   Reply With Quote
Old 01-10-2018, 12:35 AM   #9
truckster
truckster's Avatar
Originally Posted by ho70 View Post
Relay kit?
You can buy a kit (I think LMC and other vendors carry them) or you can just get a couple of Bosch relays and wire it yourself. Here's a link that might help:
http://67-72chevytrucks.com/vboard/s...eadlight+relay
Old 01-10-2018, 12:35 AM   #10
HO455
HO455's Avatar
Relay kit?
A common upgrade of our head light wiring. The factory wiring is the minimum size usable for the OEM headlamps and it will limit the output of the lights due to voltage drop. Installing a larger guage supply wire to the lights solves the problem. Then you use relays to control the new power feed to the lights. There are literally dozens of write ups on how to do this. Not to mention plug and play kits you can buy. I have done it to my Burban as my new H4 bulbs draw more power than the dimmer switch will handle.
That and having good ground connections will do wonders for even stock bulbs.
RIP Bob Parks.
Old 01-10-2018, 01:01 AM   #11
ho70
ho70's Avatar
Thanks, I red about 12 different threads and they confused me-these are great.
Old 01-10-2018, 10:24 AM   #12
Willie Makeit
Willie Makeit's Avatar
relay kit and the Hella E codes and you'll swear you're driving a different truck.
REAL German-made glass housings and lenses - not chinese-made plastic. They are THE cat's balls of headlights.
No mods to my '67 radiator support to use these lights. Remove old sealed beams, installed Hella housing. Plug and play.
I bought mine from Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Willie Makeit is offline   Reply With Quote
Old 01-10-2018, 04:11 PM   #13
StingRay
StingRay's Avatar
Hella, Bosch, Carello, Cibie, Lucas, etc. European made H4 headlights are the real deal and will be far superior to anything plastic or sealed beam. My favorites are vintage Cibie followed by Bosch and Hella. Aiming them properly is also really important. If you want to run higher rated bulbs our lights switches have circuit breakers that will trip. Relays are must at that time.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 01-10-2018, 10:49 PM   #14
AJC
I also run the Jeep Wrangler head lights. Picked them up on eBay $40 just look around. One of the best things I did. They have a good cut off. Funny thing is they work better than the one on my Wrangler.
AJC
AJC is offline   Reply With Quote
Old 01-13-2018, 01:18 AM   #15
truckster
truckster's Avatar
What years of Wrangler work for this?
Old 01-10-2018, 10:54 PM   #16
68c10airstream
68c10airstream's Avatar
Some interesting reading at "daniel stern lighting". He gets into the bulbs and i followed his suggestions with cibie's and a shielded low/high bulb and very happy with the results. I did cibie's in the late 70's and knew what i wanted. I e-mailed him with the light beam description of the low beam being wide, lighting both ditches with the hockey stick hook up the passenger's side ditch, and high beam being 2 pencil beams that really lit up the road a long ways away. He supplied me with e code cibie's and believe it or not 55/60 watt shielded bulbs that are fantastic. I told him i ran a 100 watt high beam in the 70's and he was so confident on these 55/60 watt bulbs he said he would refund me if i was disappointed. I did pay near retail but his help was the best and my opinion is my night time vision is well worth a one stop shop with experience.
68c10airstream is offline   Reply With Quote
Old 01-10-2018, 11:00 PM   #17
Joe Pass
Joe Pass's Avatar
I have used the H4 bulb and found relays are a must...been buying these with good results ...FYI
https://www.ebay.com/itm/H4-Headlamp...72.m2749.l2649
Joe Pass is offline   Reply With Quote
Old 01-13-2018, 01:36 AM   #18
beautimus
beautimus's Avatar
ttt
i also want to know what year wrangler headlights work on my 71 cheyenne
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
Old 01-13-2018, 01:57 AM   #19
suburban99
suburban99's Avatar
Originally Posted by beautimus View Post
ttt
Here's the conversion harness.https://www.ebay.com/itm/2x-H4-9003-...item3af75aa1fd
I think my headlights are from a 2010 or so wrangler. Call a 4x4 shop as they do lot's of LED swaps on these jeeps and usually keep the take outs lights. Don't forget the relays..
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 01-13-2018, 07:35 AM   #20
Hella is quality. The nice thing about the Hellas shown is they don't stand out as newfangled modern bulbs. Those other upgrade bulbs are fine if you want your headlight bulbs to be the focus, but modern light that doesn't wave a flag is just classy.
Old 01-13-2018, 07:49 PM   #21
70cst
70cst's Avatar
Great Great Thread
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-14-2018, 02:05 PM   #22
bigmac73
bigmac73's Avatar
Subscribed
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
