Old 01-11-2018, 11:35 PM   #1
jrpontiac
jrpontiac's Avatar
Wheel well liner clearance 83 gmc - Front
Just installed 3" dropped spindles on my 83 gmc SB. Was planning on cutting the springs to get another 1.5". As it sits without cutting the springs there is about 3" of clearance between the tire and wheel well. Dropping it another 1.5" will leave it at about 1.5" of clearance. Without changing out the wheel wells there doesn't appear to be a way to fix that. Are others running with only 1.5" of clearance? Is there some kinda of trick I don't know about. I don't mind an ocassional rub.
Running 245/45/20.
jrpontiac is offline   Reply With Quote
Old 03-13-2018, 01:27 PM   #2
64longbedcustom
Re: Wheel well liner clearance 83 gmc - Front
Let me know if you do remove your wheel wells. I did the 4.5 drop in the front and 6 in rear and only have the inch of clearance so I have been debating what to do since I cant really drive mine now cause it'll rub. I have a 85 C10
64longbedcustom is offline   Reply With Quote
Old 03-13-2018, 01:40 PM   #3
ultrahd4me
ultrahd4me's Avatar
Trim away. I've ran several trucks with 4.5" drop upfront with 245/45/20. You should get on the bump stop before you get in the inner fender so leave them in place.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 03-13-2018, 01:47 PM   #4
ultrahd4me
ultrahd4me's Avatar
All these trucks were around 4-1/2 and only the blue truck buzzed the fenders on a big bump.
Old 03-13-2018, 01:47 PM   #5
64longbedcustom
Yeah my inner fenders are metal so I didn't really want to mess with them if I didn't have too. I might put in some spring spacers to stiffen up the front end and see how that works.
Old 03-14-2018, 07:59 PM   #6
68longhorn
68longhorn's Avatar
Slosh tubz sells a mild drop inner fender
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 03-15-2018, 07:59 AM   #7
riz
$730 ?!?!?!?!?!
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 03-15-2018, 09:12 AM   #8
blazer2007
If you have a jack mounted on the wheelwell don,t forget to take it off and the bolt too if you leave inners on, the bolt makes a nice mark in the tire when you hit bumps
blazer2007 is offline   Reply With Quote
Old 03-19-2018, 01:22 AM   #9
bbbc10
Diggin The SquareLife
slosh tubz period
bbbc10 is offline   Reply With Quote
