Old 01-12-2018, 06:58 PM   #1
Ryan5O
Stall Speed - Daily Driver
I'm picking up a new crate motor from Jegs
http://www.jegs.com/i/Chevrolet-Perf...429K2/10002/-1
I'm running the stock th350 and gears. Do you think its necessary to install a new torque converter and if so, what stall speed would you recommend?
Thanks in advance,
Ryan
USCG "Support Search & Rescue, Get Lost"
Ryan5O is offline   Reply With Quote
Old 01-12-2018, 07:39 PM   #2
harpo231
harpo231's Avatar
Re: Stall Speed - Daily Driver
1200-1400 is close to stock
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 01-12-2018, 07:52 PM   #3
Ryan5O
I'm not that familiar with torque converters, do you think keeping the old one would be a problem?
Old 01-12-2018, 08:13 PM   #4
Bigdav160
Bigdav160's Avatar
Ideally you would measure the endplay with a special tool, stick your fingers inside to check the one-way clutch operation, and check the fluid for metal or water contamination.
Otherwise if it worked with the old transmission it's likely to work with the new one.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-12-2018, 08:16 PM   #5
demian5
demian5's Avatar
I think his issue is the cam size of the new motor.
383"/.401" Lift, 194 / 202 Duration @ .050", and 112° lobe separation
He may need a looser converter, however I don't have the knowledge to assist.
Try this article: http://www.superchevy.com/how-to/tra...ter-selection/
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-12-2018, 08:52 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That's basically a stock replacement engine, so a stockish torque converter will be just fine. It won't be happy with that Air-gap manifold though. It's be better with a Performer intake.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 01-12-2018, 09:55 PM   #7
wilkin250r
wilkin250r's Avatar
Gary
What's the difference?
Honestly, this is one of the things I hate about manufacturer's descriptions, they all say "This is great for the builder looking for more performance", but nothing about HOW it performs, where it builds power, or how it compares to other products they offer.
The descriptions for the Air-Gap and the Performer intake look almost identical, and they both say designed for idle to 5500 rpm.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-12-2018, 08:55 PM   #8
harpo231
harpo231's Avatar
- p/n 555-60402 << this the one jegs recommends
Stan
67 swb BLU MULE
Old 01-12-2018, 10:31 PM   #9
clay68c10
clay68c10's Avatar
I'd stick with your stock converter, that cam is small enough that you won't have any problems.
The air gap doesn't have the exhaust crossover under the carb. On cold starts it will run rougher since the intake will be cold for a while. That crossover helps heat up the intake and makes the rich startup mixture atomize better. In warm weather it won't make much difference.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-12-2018, 11:45 PM   #10
Pro299
Junior Member
I'd recommend sticking with the stock converter. What power that motor has is down low. Not knocking it at all as I have one sitting in the garage right now waiting on me to install it. Unless you're going to do other things to raise the power level in the upper rpm range, you won't like driving it with a loose converter. If you're going to drag race, sure, but I assume you'd have picked a different engine for that. I have a car with a 2800 stall in it. At the strip it's fun, but for normal driving, not so much.
Pro299 is offline   Reply With Quote
