Old 01-13-2018, 12:53 PM   #1
85/Silverado
85/Silverado's Avatar
Carb. to Hood clearance
I wanted to get a Velocity Stack Air Cleaner which is 10.5" tall.
Want to know if it will fit first.
85/Silverado is offline   Reply With Quote
Old 01-13-2018, 01:11 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Carb. to Hood clearance
it wouldn't fit on mine..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-13-2018, 02:23 PM   #3
blindbug
I've got the K&N 66-3030 X-Stream filter, which is 5" tall, and it is fairly close to the hood, but fits pretty well with probably 3" of clearance. SBC 350 in an 86'
https://www.knfilters.com/search/pro...x?prod=66-3030
http://67-72chevytrucks.com/vboard/a...1&d=1515867717
blindbug is offline   Reply With Quote
Old 01-13-2018, 02:29 PM   #4
mongocanfly
set a cardboard box ,that's of equal height ,on top of the carb and see if hood'll close
Old 01-13-2018, 10:17 PM   #5
Puke160
If you are running the stock hood run a straight 2×4 or a level on the lip of the fenders right above the front edge of the carb. Then just measure the clearance. The center of the hood should sit about a 1/2 inch above about the bottom of the level.
1949 Chevy C3100
1979 GMC K25
1982 Chevy C20
2000 Chevy K2500
2002 Pontiac Trans Am
Puke160 is offline   Reply With Quote
Old 01-13-2018, 10:24 PM   #6
85/Silverado
Thanks Guys. I guess that answers my question, It's suppose to be the best air filter for airflow. Even better than without a filter at all.
Tested Here.
https://www.youtube.com/watch?v=EkpsydS8JXI
Old 01-16-2018, 12:18 PM   #7
RotaryRocketeer
RotaryRocketeer's Avatar
Are you really making enough power to need that thing? Their findings indicated that the 14x3", or whatever it was, would flow enough for 500hp or so. If I'm recalling correctly...
RotaryRocketeer is offline   Reply With Quote
Old 01-16-2018, 08:03 PM   #8
duallydude63
save some $$$$ buy a air cleaner riser(factory on vans)3-4 in height then put your back on mite due the same!!!
duallydude63 is offline   Reply With Quote
Old 01-17-2018, 12:06 AM   #9
nonstop
I prefer the salad bowl myself!
nonstop is offline   Reply With Quote
