01-14-2018, 06:32 PM | #1 |
Do I have to replace power steering lines?
Got a new steering gear box from advanced auto. Instructions go on and on about replacing all the power steering hoses. Is this actually necessary? I'd really rather not have to buy all that and do all that.
01-14-2018, 10:03 PM | #2 |
Re: Do I have to replace power steering lines?
Depends on age and physical condition of hoses. If unsure of age, replace anyway. Better to have new hoses than to have one of them start leaking in the near future.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
01-14-2018, 11:21 PM | #3 |
Yeah I went ahead and did it. Seems the pressure line was leaking, and the return line is just a hose.
01-15-2018, 12:02 AM | #4 |
I recently replaced mine. Thought they were original, but not sure. Just another thing not to worry about leaking.
01-15-2018, 12:25 AM | #5 |
I would replace as well..just for piece of mind
01-15-2018, 01:11 AM | #6 |
The return line needs to be more than "just a hose". Pressure return line needs to be rated to 50 lbs (I think). Good time to put an inline filter on the return also.
01-15-2018, 09:55 AM | #7 | |
Moderator
Hose that meets SAE J2076 is specifically engineered for power steering return hoses. Max oil temp 302°F and 175PSI running pressure. You can use SAE J1019 transmission cooler hose. It's 250PSI and 302°F SAE minimum working spec exceeds Power steering return hose pressure specs. You'll find that several US manufacturers brag that their SAE J1019 Hose exceeds the minimum SAE specs. For instance some Gates J1019 hose is rated at 400PSI and 302°F. More details in my post here: http://67-72chevytrucks.com/vboard/s...d.php?t=696742
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-15-2018 at 10:01 AM. |
01-15-2018, 12:01 PM | #8 |
I replaced mine as well. Hoses are cheap I think I got mine on rock auto. They were in pretty good shape but like other guys said Peace of mind really
01-15-2018, 01:14 PM | #9 |
Cruzzzn' Vet
Yup! change them, they could be deteriorating on the inside.
01-15-2018, 03:22 PM | #10 | |
I wanted to go with a redhead steering gear, but I needed this done today so I just got a reman from Advance. Should be good enough. I'm sure it will be a world of difference from the worn out old one with 6 inches of play when you turn the steering wheel. So in order to kill that play, I've now done the pitman arm, the steering gear, and the rag joint. What else is there that may cause play? The idler arm perhaps? |
