Old 01-15-2018, 04:39 PM   #1
SteveA69
SteveA69's Avatar
Edelbrock AVS 2
anybody try the new edelbrock avs 2 carb? if so, how do you like it?
SteveA69 is offline   Reply With Quote
Old 10-01-2019, 09:28 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Edelbrock AVS 2
I know this is an old thread, but searching the forums, this is the only thread I found.
https://www.edelbrock.com/avs2-carburetors
It sounds interesting - in that I could see how the "annular flow booster design" may deliver improved fuel atomization.
I also wonder, if it really is a superior method, if edelbrock couldn't build a replacement part to upgrade our current edelbrock carbs with "Downleg boosters" to "Annular boosters"
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-01-2019, 11:03 PM   #3
truckster
truckster's Avatar
Re: Edelbrock AVS 2
This has been discussed on here before. The "booster" is the accelerator pump, so it's only operating when you're pushing down on the pedal, not when you're holding it steady. I doubt you would see a great deal of improvement.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-02-2019, 12:15 AM   #4
LostMy65
LostMy65's Avatar
Re: Edelbrock AVS 2
Thanks, I missed the previous discussion.
Old 10-02-2019, 11:37 AM   #5
NorCalC20LWB
Re: Edelbrock AVS 2
Interesting, this little gizmo is supposed to do the same thing, atomize the fuel spray. I did put it on my Eddy carb and it did seem to help on initial acceleration, not as much hesitation. Something to do with modern gas w/ethanol not atomizing as well.
Cheaper than a new carb.....
https://thompsonperformance.com/
NorCalC20LWB is offline   Reply With Quote
Old 10-02-2019, 02:26 PM   #6
RichardJ
Re: Edelbrock AVS 2
>>This has been discussed on here before. The "booster" is the accelerator pump, so it's only operating when you're pushing down on the pedal, not when you're holding it steady.<<
NOT
Accelerator pump nozzles are paired in front. The Booster Edelbrock is referring to is also called a Secondary Venturi. Not to be confused with primary and Secondary Throttle Bores. The Throttle bores, Primary & Secondary are called Primary Venturis. The Booster Ring is the Secondary Venturi.
The discharge from the Booster comes from the Main Fuel Jets, NOT the Accelerator Pump.
norcalc20LWB, your gizmo is a modification to the Accelerator Pump Discharge Nozzle.
RichardJ is offline   Reply With Quote
Old 10-03-2019, 12:30 PM   #7
LostMy65
LostMy65's Avatar
Re: Edelbrock AVS 2
So, what's your thoughts on the advantages? Is there validity in Edelbrock's claims?
Old 10-03-2019, 06:50 PM   #8
LostMy65
LostMy65's Avatar
Re: Edelbrock AVS 2
That takes me back to the second part of my question above:
"I also wonder, if it really is a superior method, if edelbrock couldn't build a replacement part to upgrade our current edelbrock carbs with "Downleg boosters" to "Annular boosters"
