01-16-2018, 04:11 PM | #1 |
2wd to 4wd conversion, how hard is it?
Ive been needing a frame for my 72 gmc k25 and have been holding back as long as I can on buying a 73-87 frame to use, they are super cheap where I am. There is a 71-72 chevy 2wd here in town that is much better shape and than my gmc and I was wondering how hard it would be to convert it to 4wd using the 4wd stuff from my gmc?
My thinking behind this was I can drop my 4wd stuff under the chevy and be ready to go. Then my dad could have my gmc cab to build his. |
01-16-2018, 04:13 PM | #2 |
Re: 2wd to 4wd conversion, how hard is it?
The search feature brings up a ton of stuff for this. Check it out.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-16-2018, 04:41 PM | #3 |
This is one of those situations if you have to ask it's probably not for you...
The two wheel drive frame has a different taper than the 4x4 resulting in 42.5" spring centers versus 40.5" so all of the brackets and things at rear are different. As mentioned above, it can be done and has but it is not a "bolt on" solution.
01-16-2018, 04:52 PM | #4 | |
I figured it wasn't bolt on. I knew there would be modifications required. I just wanted to know exactly how hard it would be. I know guys do it all the time and vise versa so I figured it shouldn't be to bad. |
01-16-2018, 04:49 PM | #5 |
The way I look at it is, if you have a welder and a big enough want then you'll find a way. It'll be more work to convert a 2wd frame to 4x4, but in the end you'll have more pride in it. Depending on your skill level you may want to just find a 4x4 frame, and just do a body swap. At least that's my 2 cents.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
01-16-2018, 04:55 PM | #6 | |
01-16-2018, 05:08 PM | #7 |
6>8 Plugless........
If you do get the 2wd frame, make sure it has leaf spring rear. You can use a coil spring rear frame, but they aren't the same and require more work to get the leaf springs on the rear. What's wrong with your K25 frame right now?
The 73-87 frames are wider. They can be put under the 67-72s but it takes building new body mounts, and it takes some work to get the bed on the frame correctly. I've seen a lot of hacked ones and it is depressing.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 01-16-2018 at 05:14 PM. |
01-16-2018, 08:42 PM | #8 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
01-16-2018, 10:48 PM | #9 |
Yes, good point. I have photos in one of my PB accounts of mine but I can't get them to open thanks to PB. They are in my thread and broken too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
