Old 01-17-2018, 12:16 PM   #1
Shanehenrymusic
Underbed Gas Tank for 59 Fleetside??
Hey Guys,
I know there's been multiple gas tank threads on here- could anyone point me to an underbed fuel tank for a 59 fleetside? I'm going with a 5.3 so I'll need the EFI option. The ones on CPP's site specifically say they do not fit 58-59 fleety's.. Looking for something that does require a massive amount of fab work. THANKS!
Shanehenrymusic is offline   Reply With Quote
Old 01-17-2018, 01:23 PM   #2
buggy5872
buggy5872's Avatar
Re: Underbed Gas Tank for 59 Fleetside??
I used a Tanks inc UT-N under my 59 fleetside. They make the tank for FI application also.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 01-17-2018, 05:00 PM   #3
_Ogre
_Ogre's Avatar
i have a nolimit efi tank under my 58
the bigger tank requires the rear x-member to be moved back (my choice)
smaller tank does not and has a notch around the x-member
shop air compressor timer
Old 01-17-2018, 09:14 PM   #4
mr48chev
mr48chev's Avatar
I think the frame width on those at the rear is the same as on my 71 and that can be a tad snug for something like a Suburban tank. I've got a 40 gallon suburban tank for the 71 but it will be a challenge to put it in and I'll have to lift the bed off to do it. That one has a 500 Cad and will do some long trips with a trailer on the back though.
My ongoing truck projects:
Old 01-17-2018, 09:46 PM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
I used this in my ‘55.2:
http://www.tanksinc.com/index.cfm/pa...rod/prd129.htm
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 01-17-2018, 11:41 PM   #6
Jesse Z
I like that Mustang tank because it has the hole for the sender/etc on the top instead of the bottom like a stock Mustang tank.
Jesse Z is offline   Reply With Quote
Old 01-18-2018, 10:12 AM   #7
jkmhb
I also using a Mustang tank in my '58 Fleetside - the Spectra premium F28CFI (69 Mustang with in tank fuel pump and fuel return). The sending unit/fuel lines are on the bottom. One plus is you can remove them without pulling the tank. I used a classic instruments sn34 to solve the sending unit as a Mustang runs "opposite" the factory fuel gauge on the truck.
1958 Chevy Short Fleetside - 350 Stealth Ram FI/700R4/Old Air
1965 Corvette Convertible 350/Richmond 5-speed
jkmhb is offline   Reply With Quote
Old 01-21-2018, 06:17 PM   #8
Shanehenrymusic
my issue is i have 29.5 inches width, by 20.5 inches length. I went with a C4 corvette rear end and the Anti-Roll bar take up that space. I'm probably best off to have a custom tank made with my dimensions. Here's the images..
Old 01-22-2018, 10:45 AM   #9
gigamanx
Jeeez man, what kind of power are you putting into that thing? That's one beefy rear end.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 01-22-2018, 04:54 PM   #10
Shanehenrymusic
haha! Its actually not as beefy as it looks. We are going with an LS 5.3 - The bracing over the rear is just to add support to the frame since we had to remove the original crossmembers & C-Notch for it to fit. Here's more pics of the room I have to work with for the Gas Tank... The anti roll bar is the reason we had to demo that crossmember.
I might just have a kustom tank made to my dimensions.
Old 01-22-2018, 05:55 PM   #11
mongocanfly
mongocanfly's Avatar
have you checked out boyds?....you might have to redo the rearmost x-bracing to clear a tank...would be easier to get a tank set and then build your x-bracing around it
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-22-2018, 07:51 PM   #12
Shanehenrymusic
Here's the Pics! I have 29.5 width by 20 inches to work with: keep in mind the rear support is just for mock up to keep the frame square and will be taken out.
I'll look into boyds - Thanks!
Old 01-22-2018, 08:59 PM   #13
mongocanfly
look at this from boyds...http://www.fueltankparts.com/55-59-c...inum-tank.html
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-22-2018, 09:04 PM   #14
Shanehenrymusic
I was hoping to find something thats at least 20 gallon...
Old 01-22-2018, 09:09 PM   #15
mongocanfly
he also custom builds tanks to your needs...and you can get it with the pump already mounted as intank pumping..
look at some of the other year model truck tanks...you might find one that'll fit your needs..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-22-2018, 09:14 PM   #16
mongocanfly
here's one for 67-72 truck....http://www.fueltankparts.com/67-72-s...-fill-777.html
Mongo...aka Greg
RIP Dad
RIP Jesse
