Installing Mirrors - HOW?
I hate the mirrors on my truck, and bought some to throw on instead...pretty much the standard fare. Taking the old ones off was a no brainer, but naturally the new ones are a different hole pattern and probably will mount in a slightly different position anyways, but I'm stumped.
I have a backing plate with threaded holes so you can mount with machine screws, but have no idea how to access the backside (inside the door) to install. I pulled the plastic door panel, but there isn't really an opening that will get a hand in there. Is there some kind of trick to this? |
#2 | |
The Older Generation
Re: Installing Mirrors - HOW?
Have a good extendable magnet? It would probably take two people. LockDoc
![]() Join Date: Feb 2016
I pulled the backing plates up with about 8 feet of light guage wire through the mounting holes and down to the bottom of the door through a speaker cutout. Then held them in place with studs until I got a screw started through the mirror. I think any access inside the door should work. I didn't have a helper available the day I mounted my mirrors so it took a little while. I have a write up on page 11 post 257 of my WMB thread below for more details and pictures.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Feb 2009
I pulled the panels, which is easy enough. My son held the mirror while I positioned the plate, and I recall using a piece of duct tape to assist placement. Took a minute or so a mirror. Unless you have huge hands or really short arms, there's ample room through the door to reach that plate.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
get a neighborhood kid with small hands to reach in and hold the backing plate. bin there done this. anything else will make you cry alot.
I used a magnet and place the nut on it. Then moved the magnet/nut to the hole from with in. This places it in the area and allows you to thread the screw from the outside. Repeat two more times and you will think it was so easy you will redo it for fun.
