Active Member
![]() Join Date: Dec 2017
odometer issue
Hi folks , I went for a nice ride Sat. in Our 63,, The speedo seemed to warm up and register as it should However I got no action from the odometer can this be fixed or repaired?
Check our For Sale section. You should find a decently priced used one--likely at a much lower price than a repair shop (you might find) would charge for repairing yours.
Sam |
![]() ![]() ![]() Join Date: Jan 2018
Re: odometer issue
Not sure if this is the exact same issue you were having, but on my 63, the speedo needle started bouncing on me with a range of about 10 mph and the odometer stopped spinning. I replaced the speedo cable, and still had the same problem. Ended up pulling the speedo and odo out and noticed that the plastic gears on the inside were slightly chewed up. My suspicion was that the odometer had stopped spinning causing the speedo to bounce back and forth and not hold constant. I set the odo at a random number and watched it spin till it got to a certain point and stopped spinning. I couldn't figure out why it stopped spinning so I just removed it. It does not have the original engine, so it didn't bother me to not have the odometer in the truck.
Sorry I didn't think to take pictures of it when I took it apart, and the truck is at home while I'm in college so I won't be able to get any pictures of it.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
