01-25-2018, 02:20 PM | #1 |
Electronic Flashers Clicking?
Hay All,
after installing led's and the electronic flashers (blinkers/hazards) they work great (installed maybe a month ago) with the clear gmc (lmc truck) lenes and amber led bulbs they look amazing. and work great. Fast forward to today walk outside and my truck is making a clicking sound open the door and felt the electronic flasher in the hazard spot (it was clicking without the hazards being on) i turned on the hazards (work fine) turn off and the formentioned clicking continues (noticed a slightly diffrent clicking rythem between the harzard on&off) i pulled the hazard flasher out (no more clicking lol) turned key on/started truck. the blinker flasher starts making the same clicking noise (turn key off) it stops. im confused. my set up is two electronic flashers (w/external ground wire) connected to a polarity adapter.
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG) |
01-25-2018, 02:24 PM | #2 |
Re: Electronic Flashers Clicking?
Try swapping the two flashers to see if the problem moves, stops, or stays the same.
Can you show us a simple drawing or photo of how the flashers are installed.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-25-2018, 03:58 PM | #3 | |
This what im using (trying to share pictures is A PITA with photobucket now a days) they are installed the same as a standard flasher (plug in polarity reverser-plug flasher into that) + the ground wires.
01-25-2018, 07:11 PM | #4 |
The way it is supposed to work is the flasher unit is hooked to the fuse and the contacts in side are closed and 12 volts positive goes to the switch (turn or hazard). When you operate the switch the 12+ goes out to the light bulb through the filament and to ground. The current draw of the bulb causes the bimetallic contact in the flasher unit to heat up and open the contact then it cools and recloses repeatedly until the switch is opened back up (turn or hazard) Because heat up time of the bimetallic contact is affected by load trailer lights or bigger bulbs affect the flash rate.
The problem with LEDs is they don't have enough load to make the bimetallic contact to heat up. One of the cures is an electronic flasher. It is a powered logic device (thus the need for the ground wire). It too is looking for a ground path so it can start flashing. My guess is that you have a slight ground in the steering column wiring or the switch itself. Try to recreate the problem and unplug the connector at the base of the column. If the problem disappears then you will have to access the turn signal switch/hazard switch for an inspection. If the clicking continues then there is a ground between the flasher and the plug. Your new flashers may be very sensitive to the ground needed to trigger operation and just damp wires may cause it to operate. I am unfamiliar with the operation of the polarity reverser. Did you use them? Did you have to make sure all of the new LEDs were plugged in the same way for correct polarity at each socket?
01-25-2018, 07:32 PM | #5 | |
its been wet and rainy out so damp ground wires could be a issue all the bulbs are 1157-1156 replacments (only go in one way) becouse the leds are reverse polarety i had to use the reversers (just switches the two flasher pins around. i also have a electronic flasher that doesnt need a external ground. (dont use it couse its silent - doesnt make a clicking noise) will put it back in when the weather allows.
