Old 01-29-2018, 06:31 PM   #1
sprinter138
Electrical Help!
So I'm new here and the proud new owner of a 1969 C-10 that I purchased just four months ago. It's already been an adventure! I removed the gauges from yesterday because I'm doing some refresh work to them. I started by disconnecting the switch to the lights and then remembered I need to disconnect the battery. So after disconnecting the battery I continued to and disconnected the wiper switch, speedometer, tach, oil pressure and main plug to the gauges (didn't see any other connections). I went back out to the truck and it won't start now. Just curious, is there some connection in the gauges that completes a circuit allowing the truck to start? Checked my battery and it's good, has a full charge. I even plugged the gauges back in (all except oil pressure) and still nothing. The previous owner had a bit of a wiring mess going on. I don't know if I possibly tripped something or unknowingly disconnected something else.
Also, suggestions on where to get the best price on a new harness? I'm thinking maybe just start fresh?
sprinter138 is offline   Reply With Quote
Old 01-29-2018, 06:49 PM   #2
samkost
samkost's Avatar
Re: Electrical Help!
Just a thought,
If you removed your gauge cluster and your truck is an automatic, make sure your truck is in park or nuetral.
I know this because it happened to me.....
Good luck
samkost is offline   Reply With Quote
Old 01-29-2018, 09:05 PM   #3
sprinter138
Originally Posted by samkost View Post
Just a thought,
Good luck
I tried starting in park and neutral. We've checked fuses and even reconnected all the gauges...still nothing. I'm thinking I must have unknowingly disconnected something somewhere. The mystery continues....
Old 01-29-2018, 07:04 PM   #4
ga-stepside
ga-stepside's Avatar
Also plug that oil line going to the gauge before you start the engine or you'll have a real mess, don't ask how I know that!!!
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 01-29-2018, 09:06 PM   #5
sprinter138
Great tip.....Thanks for saving me from that beginners lesson!
Old 01-29-2018, 10:12 PM   #6
dmjlambert
dmjlambert's Avatar
What is the symptom? No cranking, or is cranking and won't fire up?
Old 01-29-2018, 10:25 PM   #7
BigMike56-72
BigMike56-72's Avatar
Have you checked your Neutral Safety Switch to make sure its connected? I am having issues with mine so I am reading a lot about it and if you do have one. It maybe the issue. For me my truck didnt come with auto trans so I dont have it but still having issues with my reverse lights not coming on. Good luck. I know the feeling.
BigMike56-72 is offline   Reply With Quote
Old 01-30-2018, 10:38 AM   #8
jkeady
jkeady's Avatar
Just throwing it out there in case you are like me... did you reconnect the battery?
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
